How to install Scion tC projector headlights!!!!!????????
Old Aug 2, 2007 | 01:11 AM
ScionGirl112's Avatar
Default How to install Scion tC projector headlights!!!!!????????
i tried searching this forum for some instructions/pics on how to install projector headlights, but i couldn't find anything... :eyebrow:
I NEED HELP!!! i just got my new projector headlights and i have no idea how to install them...
if someone has pics or at least instructions it would be very helpful!!![/b]
Old Aug 2, 2007 | 01:29 AM
tc-guy's Avatar
to install headlights on the tc u need to first remove the front bumper cover. there are four clips on the top (remove with a flathead screwdriver) four screws on the side inside the fender and bout 6 more on the bottom. once u get all the screws and clips off pull the bumper cover towards u on each corner (it held on by a slight L-shaped clip. once u get both side undone the bumper will come straight off. the headlights are held on by 3 bolts (2 on top and one on the side where the L-shaped bracket is on the fenders) and is clipped on towards the middle. you'll see what i mean once u get to this point. stick a flathead inside the clip and pry the tab out. at that point just do the reverse of installation to put everything back. i hope this helps. sorry i have no pictures.
Old Aug 2, 2007 | 01:30 AM
OleksiyMU's Avatar
OhioScions
yep what ^^^^___ said
Old Aug 2, 2007 | 01:49 AM
this is the lights that i got...and it has wires sticking out from the little light bulbs on the bottom. i'm not sure what to connect them to. any idea? do i need to buy anything else to get it wired?
Old Aug 2, 2007 | 02:09 AM
tc-guy's Avatar
most of all the aftermarket headlights are just plug and play. it plugs directly into the stock plugs. the only thing with the ones u have there is that i heard it doesn't fit too well and people ended up needing to bend the metal or cut it directly where the top of the headlight goes.
Old Aug 2, 2007 | 02:21 AM
DjEzE's Avatar
mine didnt fit one bolt on the left side. just tighten up the other ones and you should be fine. it took me 45 min to install em. good luck
Old Aug 2, 2007 | 11:50 AM
ack154's Avatar
I think before I installed those I would run a small bead of silicone around the seal. A couple people have reported them fogging up after a little while.
Then again, I wouldn't have bought them at all, but if I had... that's what I'd do.
Old Aug 2, 2007 | 03:26 PM
i suck at buying things for my car. i hate researching before buying and always end up with crappy stuff. i'll see if i can install them this weekend. hopefully they'll fit fine. i just wanna buy some bumper clips before i take my bumber off and break all the current clips... :eyebrow:
maybe i'll take some pics and post them - WITH DESCRIPTION ON WHAT THE HELL I'M DOING... hehe
good luck to ME :doh:
Old Aug 2, 2007 | 03:48 PM
Menace's Avatar
Just take it to a shop if you are not confident, they'll charge you like $50 bucks. Give them the finger if they ask for more.
Old Aug 2, 2007 | 03:55 PM
HR_Guy's Avatar
To remove the bumper... http://www.club-tc.com/forums/exteri...r-removal.html
To remove the headlights... http://www.club-tc.com/forums/exteri...t-removal.html
Then reverse everything to put it back together. This was the guide I used the first time and it worked perfectly. Good luck.
Old Aug 2, 2007 | 04:00 PM
datboiant's Avatar
you have to get some connectors for those wires sticking out. This post should tell you how since the headlights are probably similar. https://www.scionlife.com/forums/vie...jector+install
Old Aug 2, 2007 | 10:34 PM
tc-guy's Avatar
what area are u located. maybe u can get someone from SL to help u out. if u were near me i could help u.
Old Aug 4, 2007 | 07:42 AM
SquallLHeart's Avatar
i'll install them for ya!
Old Aug 7, 2007 | 12:54 AM
did i mention that i'm un-patient.... anyhow, my buddy from work works on cars (i just found out today)... so he'll install the lights for me this wednesday.
SquallLHeart: but it doesn't mean that i didn't want you to install them and it doesn't mean that i won't be showing up to meats....
ttyl....
Old Aug 7, 2007 | 06:43 AM
ohhh okayyyyy.. well.. my number is available if you run into any problems!
Old Aug 7, 2007 | 06:57 AM
RnB180's Avatar
can you post a pic after the install?
Old Aug 7, 2007 | 07:17 PM
pudgy1's Avatar
i used this thread to install mine.
unfortunately theyre not your's exactly and they were exactly like mine but i can imagine it being any different
Old Aug 7, 2007 | 07:19 PM
pudgy1's Avatar
^^ i meant to say " i CANT imagine it being any different"
Old Aug 7, 2007 | 07:25 PM
kanundrum's Avatar
i linked her to the thread i made, hopefully it helped :D
Old Aug 7, 2007 | 08:57 PM
picture of me??? haha...jk....of course i'll post a pic. i need to fill in my profile with pics too...
