Throwing a CEL w/stock motor and 15k miles Any ideas?
Old Aug 2, 2007 | 03:43 AM
mdkflip's Avatar
Default Throwing a CEL w/stock motor and 15k miles Any ideas?
On the way home tonight my Check Engine Light came on and it kind of caught me off guard. I haven't done any modifications to the engine (not even a CAI), so it's not headers or anything causing the problem. I recently changed the oil (switched over to Mobil 10w-30), and the car has no problems. I checked the fluids when I got home and everything looked good except for the washer fluid. Is it possible to throw a CEL for low fluid, even washer fluid? I'm going to check the oil level tomorrow morning before work, but until then I'm left scratching my head. I hope it's something I can fix on my own, because the dealership I would have to go to is far, and I can rarely get time off from work.
Old Aug 2, 2007 | 06:19 AM
ricexizxgood's Avatar
The washer fluid shouldn't throw off the CEL. And switching oil shouldn't throw off the CEL also. I would either bring it back to the dealer or just get a code reader of it.
Old Aug 2, 2007 | 12:44 PM
kuo34's Avatar
Swing by an auto parts place. They often run codes for free so you can at least get an idea.
Old Aug 2, 2007 | 12:46 PM
ack154's Avatar
I don't know if the tC is affected by this or not... but I'd try removing the gas cap and tightening it back up and make sure it clicks 4 or 5 times.
Other than that you're going to have to get the code read and go from there.
Old Aug 2, 2007 | 01:54 PM
HeathenBrewing's Avatar
10w30 is much to thick at startup. This may have caused excess pressure in the engine, throwing a code.
Stick w/ a 5wxx or 0wxx.
Old Aug 3, 2007 | 05:36 PM
mdkflip's Avatar
Default update
Well it's definitely not the gas cap. I still haven't gotten myself some washer fluid, but I highly doubt that is the issue. I'm just going to have my uncle read the code for me, so at least I can narrow it down. Just a pain in the ___ going through the dealer, but it may end up coming to that.
12xb
Nov 7, 2015 03:44 PM
eatcrispycreme2
Jan 30, 2015 03:43 AM
DeannaTroia
Jan 10, 2015 12:37 AM
cid_mcdp
Jan 5, 2015 02:45 PM
baker08tc
Dec 30, 2014 12:02 AM
