new cold cathodes installed
Old Aug 3, 2007 | 03:14 AM
boxbetold's Avatar
Default new cold cathodes installed
I like these alot!! They have a cool deep blue color when you actually see them in person...and as for the 30 minute install...hahaha yea right took me about an hour and half for a pretty clean install in my opinion. but ne way here are some pix.
But i do have one question!
Ok i used an add-a-circuit and there was a 10 amp fuse i had to take out of the fuse box and add on to the add-a-circuit. Next i take my box out at night and my drivers side headlight is as bout as bright as my parking lights and it would switch to high beams! The passengers side headlight is fine though. Im thinking either i have a bent wire somewhere or the add-a-circuit cant handle that fuse i had to add on? If someone could put some input on this, that would be great! Planning on checking it out tomorrow when i got some sun rays!
Old Aug 3, 2007 | 04:10 PM
aalbertson3's Avatar
Looks great! Did you get them from Oznium?
Old Aug 3, 2007 | 07:48 PM
boxbetold's Avatar
yep...great guys and cheap prices...still waiting on my 16 led dome light thought, been on back order for a while
Old Aug 4, 2007 | 09:17 PM
boxbetold's Avatar
No one has any suggestions on my headlight deming problem!!! i have tried just about everything!
Old Aug 4, 2007 | 09:22 PM
Ghost_1's Avatar
Try this real quick and let me know what happens. Take the add-a-fuse out, and replace with original or like 10 amp fuse. Test the head lights. See what happens. If the headlamps go back to normal find another fuse to use.
Electrical work can be a pain in the ****. If a wire is bent it will still work, however if the insulation around the wire comes off or gets rubbed off and it touches something it can blow a fuse/fusible link. Electrical stuff in car and in most cases will either work or not. let me know what happens. Also which fuse did you use?
Old Aug 4, 2007 | 11:12 PM
boxbetold's Avatar
yea when i take the add-a-circuit out and put the original 10 amp fuse back into the headlight fuse holder the headlights work fine...but obviously my cathodes wont because they are not tapped into that fuse location! Ive tried every fuse location with the add a circuit ex. headlights, radio, ignition and so forth.
What i am probably going to end up doing is just forgeting the add a fuse and run an inline fuse and tap it into the cigarette lighter or something...dang i hate electrical stuff!
Old Aug 4, 2007 | 11:14 PM
boxbetold's Avatar
Also...just had a thought! Im running a 3-10 amp capacity add a circuit...could this be a problem since the headlights themselves run off 10 amps?
Old Aug 5, 2007 | 12:18 AM
Ghost_1's Avatar
yeah, more then likely. you shouldn't stack them. like i said electricty is funny like that. in theory you should be able to get away with something like that. lol. you can get wire taps that just clip on to the wires. i hate them but i know people who swear by them.
Old Aug 5, 2007 | 03:46 AM
boxbetold's Avatar
wire taps?
Old Aug 5, 2007 | 06:08 AM
Ghost_1's Avatar
When it comes to electrical wiring I'd suggest going the inline-fuse route. Better protection for anything connected. That and you won't have to give yourself a headache. lol
the "wire taps" some look like the picture in this link
http://www.nelcoproducts.com/shoppin...pid=220&cid=66
Basically you put a wire in one end and connect the extra wire and crimp. No soldering. I don't like them cause I've seen them come loose over time. there are several different types, but I still believe in the flux, solder, heatshrink tubing method. But I'm a little OCD about that kinda stuff. lol
Old Aug 5, 2007 | 06:29 AM
boxbetold's Avatar
and where would the wire with the inline fuse lead to from my switch...sorry im an electrical idiot!
Old Aug 5, 2007 | 08:08 AM
jwaj2002's Avatar
TOCC
for the cathodes as long as they are on a switch I'd just run them straight to the battery (its what I did, for something like leds that draw no power at all, you can easily use the add a fuse
Old Aug 5, 2007 | 08:14 AM
jwaj2002's Avatar
TOCC
the cathodes draw a good deal of power so you might need (if you want to use the add a fuse) to use a 20 amp fuse to begin with, also what your going to find out (if your dealers are like mine) is your going to need to build your own fuse block and just run another power wire to the battery, mine voided a warranty because of an add a fuse, and charged me $60 for a fuse
Old Aug 6, 2007 | 03:54 AM
boxbetold's Avatar
***UPDATE***
I took out the add-a-Sh**...haha and ran a wire to my amp that is powering my subs, to my switch for the cathodes. Works very nicely now! Never thought of that before but it just came to me haha. And the amp is already grounded and stuff so all it took was one little wire to the switch!
Another question...
I want to put my switch in the empty tab by the e-brake but couldnt find the bolts to take the console off...Im guessing they are under the carpet? How would i go about doing this?
Thanx for the help guys
Old Aug 6, 2007 | 04:03 AM
jwaj2002's Avatar
TOCC
one screw in the back of the center console, that pocket behind the e-brake then just pull at the front it has 2 clips and 1 screw, its a philips and a 10mm screw/bolt
Old Aug 6, 2007 | 05:10 AM
boxbetold's Avatar
ah i c...thanx a lot!
randode
44
Jun 29, 2004 04:19 PM
randode
Nov 20, 2003 05:46 PM
Besk_one
Nov 17, 2003 09:28 PM
randode
15
Oct 31, 2003 09:50 PM
BlueBox
9
Sep 25, 2003 04:36 PM
