245/30/19????????????????????????
Old Aug 4, 2007 | 03:37 PM
texasisbigger's Avatar
Default 245/30/19????????????????????????
Hey there. I am currently running 215/35/19's on 19x8 40+offset and comming to the time a buying new tires. I am dropped on STECHS
I want to be rid of the "stretched" look. The tire should be wider than the wheel.
Anyone know how the 245/30/19 series will work with my setup?
Anyone know where I can get a set for less than $1200???
And yes I have actually spent about a week searching this forum, and other resources.
Thanks, Brian
Old Aug 4, 2007 | 07:10 PM
Hat_Trick_Hokie's Avatar
I'm not sure, but they sound a little wide? Might have some rubbing problems with a 245. Just a guess tho...
Old Aug 4, 2007 | 07:34 PM
topcivic1995's Avatar
yeah i work for americas tire company and it doesnt tell me thats a fitment for the vehicle when you go to a 245 make sure your dealers okay with yuo goin that wide warranty issues other speedo goin to be off im have stech with 225-35-19 and it looks perfect rubs a lil when you go over bumps but nothing major definitly dont think i would go with a 30 series 35 series is bad ride as it is
Old Aug 7, 2007 | 10:48 PM
Luc1f3r's Avatar
Originally Posted by topcivic1995
i have stech with 225-35-19 and it looks perfect rubs a lil when you go over bumps but nothing major definitly dont think i would go with a 30 series 35 series is bad ride as it is
x2
Old Aug 8, 2007 | 11:24 PM
deflaytedwayz1's Avatar
definately a 225-35-19... i think 245 you will have extra tire hanging over and not sure how much room you're going to have between the tire and fender. and 1010tires.com tells you all the specs about the tier size. go to compare tire specs or something like that and you can type in your stock size 215/45/17 and both of those 19" sizes and it will tell you everything from tire diameter to what width wheel best fits and how far your speedo will be off!
Old Aug 8, 2007 | 11:42 PM
LivNLo94's Avatar
Right now I'm on S-Techs With 19x8 40offset
225/35/19 tires, they have a little strech to them but not as bad as your 215's.....and they rub a lil on dips
the 245/30/19's are going to rub on your ride fo sho........
My new wheels are 18x8.5 50offset 245/35/18 tires (Extra Wide)
So I Just Ordered TRD Springs and Sway From McGeorges about 30 minutes ago, so I Should be OK with this new set up......
dqlostsoulz
Scion tC 1G Wheel & Tire
10
Dec 30, 2008 08:15 PM
