sub making a vibrating noise!
Old Aug 16, 2007 | 03:38 AM
mrfuzzy4's Avatar
From: 'Burbs Farmington Hills - go to school in Boulder, CO
Default sub making a vibrating noise!
it sounds like the top plate is vibrating against something. its kinda higher pitched, and it stops if i push on it a little. do i need to take an audio recording or do u know what im talking about. how do i make it stop its hella annoying! thanks!
Old Aug 16, 2007 | 02:47 PM
mandos's Avatar
Sounds like it's misaligned and the sound you're hearing is a coil rub.
Needs to get a recone 99% of the time if it works only when you press on it.
Old Aug 16, 2007 | 04:09 PM
mrfuzzy4's Avatar
cool how do i do that?
Old Aug 16, 2007 | 04:13 PM
mandos's Avatar
Take it in to the shop you bought it from or contact the manufacturer.
Old Aug 17, 2007 | 12:13 AM
mrfuzzy4's Avatar
do i need to send it in or can i take it to a shop? i mean are they going to tell me to send it in or take it into a shop?
Old Aug 17, 2007 | 12:58 AM
bigshrek's Avatar
check that you dont have a screw that stripped the threads on the box, that causes them to rub and make a loud squeaking noise every time the bass hits
Old Aug 18, 2007 | 03:32 AM
mrfuzzy4's Avatar
bump and how much will it cost ish?
Old Aug 18, 2007 | 05:08 AM
jwaj2002's Avatar
TOCC
how much did you pay for the subs?
Old Aug 18, 2007 | 04:47 PM
mrfuzzy4's Avatar
got it off SL here, as a complete setup, a great setup actually! but i think he said 50ish
Old Aug 19, 2007 | 02:19 AM
jwaj2002's Avatar
TOCC
if they aren't worth alot new, then your best bet is to just replace them, the only ones worth reconing are the ones that are several hundred a peice, cause on the cheaper ones a recone can be almost as much as a new sub
meowtc
Mar 5, 2015 02:28 AM
brownSys
Feb 27, 2015 04:20 PM
evolving_machine
Jan 13, 2015 08:04 PM
randode
24
Nov 20, 2003 10:58 PM
32
Nov 5, 2003 03:49 PM
