sub making a vibrating noise!
From: 'Burbs Farmington Hills - go to school in Boulder, CO
it sounds like the top plate is vibrating against something. its kinda higher pitched, and it stops if i push on it a little. do i need to take an audio recording or do u know what im talking about. how do i make it stop its hella annoying! thanks!
if they aren't worth alot new, then your best bet is to just replace them, the only ones worth reconing are the ones that are several hundred a peice, cause on the cheaper ones a recone can be almost as much as a new sub
