Rear left tire wearing chopy
Old Aug 23, 2007 | 12:35 AM
KoolBox's Avatar
Default Rear left tire wearing chopy
My rear left tire is wearing chopy in the inside,need to know what can be the cause please .
Old Aug 23, 2007 | 03:11 AM
low_down_xb's Avatar
could be an alignment issue, if it under warranty have them check it out, but most likely its just because you never rotated your tires, keep up on it and do it every other oil change, and check your tire pressures too
Old Aug 23, 2007 | 05:43 AM
OldYeller's Avatar
The rear allignment is generally no adjustable. I would have it checked for damage and balance.
Old Aug 23, 2007 | 03:47 PM
burstaneurysm's Avatar
Yea, the only real adjustment you can make to the rear is camber.
Old Aug 26, 2007 | 06:37 AM
FlynHawn's Avatar
Default tire wear
just replaced tires on my box, the 18" tires did wear choppy on the inside of the left rear, my problem was that I did not rotate the tires when they needed to be, if they start to make noise, good indication that perhaps they need to be rotated! Hope this helps!
evolving_machine
Oct 21, 2023 01:16 PM
scionlife
371
Jun 2, 2015 11:00 PM
evolving_machine
Jan 13, 2015 08:04 PM
TheTripleC
Jan 4, 2015 06:46 PM
George
12
Oct 6, 2003 02:03 AM
