Taillights won't light up? Only when Braking or Turn Signals..
Old Aug 26, 2007 | 05:24 AM
sceme29's Avatar
Default Taillights won't light up? Only when Braking or Turn Signals..
My Tail Lights won't turn on? I know it's not the bulbs cuz they work when I brake and when I use the turn signal they work too.
It's as if I had my lights off. At night when I turn on the lights my headlights turn on but my tail lights no go?
Any one knows what to do?
____
Old Aug 26, 2007 | 05:49 AM
tonytc05's Avatar
Check your taillight fuse under driver side dash.
Old Aug 26, 2007 | 02:43 PM
ack154's Avatar
Have you changed your taillights or are they OEM?
Old Aug 27, 2007 | 12:09 AM
fast5's Avatar
Most bulbs are dual filament check ur bulbs. Don't rule them out
Old Aug 27, 2007 | 02:11 AM
sceme29's Avatar
i have stock tail lights. and i just noticed its all of my lights except my headlights. My parking lights wont come on. nor will the side yellow markers on the headlights and the license plate lights wont either
Old Aug 27, 2007 | 02:29 AM
ack154's Avatar
That sounds like a fuse then.
Old Aug 28, 2007 | 01:48 AM
sceme29's Avatar
Is it a fuse that i could find at like a Pep Boys or Dealer?
And where would this fuse be located?
_____
Old Aug 28, 2007 | 01:07 PM
Smuckers's Avatar
It's the 10 amp fuse under your dash. In the corner of the box.
Also extra fuses are in the Fuse box cover in the engine compartment. There is also a fuse remover tool you'll need.
Old Jun 12, 2020 | 09:18 PM
LashelleC's Avatar
Originally Posted by sceme29
My tail lights wont turn on? i know its not the bulbs cuz they work when i brake and when i use the turn signal they work too. Its as if i had my lights off . At night when i turn on the lights my headlights turn on but my tail lights no go? any one knows what to do?
Hey, did you figure this out? having the same problem
Old Sep 2, 2020 | 08:54 PM
Brookelynn1418's Avatar
was it the fuse?? Has anyone tried this and it worked??
Old Sep 3, 2020 | 02:28 PM
62Fender's Avatar
Describe what's wrong with your tail lights. If only the brake and turn signals work, your "running" filaments are probably burnt. If your amber running lights are also out, you may have a burnt fuse.
Old Sep 7, 2020 | 12:29 AM
I got it fixed it was just the fuse! Thank you!
gan777
47
Jul 4, 2010 02:41 AM
AngHellicTc
Scion tC 1G Aero & Exterior
Mar 19, 2010 10:13 PM
wikkyshimmy
Mar 19, 2008 12:27 AM
STNC
30
Aug 30, 2007 05:28 PM
Celt
Apr 17, 2005 11:26 PM
