VSC and Traction Control warning lights on
Old Aug 27, 2007 | 06:48 PM
syring65's Avatar
Default VSC and Traction Control warning lights on
A friend of mine loaned me his ODBII reader for my wifes Taurus and he wanted to see if it would work on my 05 xB...long story short it doesn't read xB's. He ended up setting off the VSC and Trac Off warning lights. I purchase my own ODBII reader that is compatible with a Scion but no codes showed up, I later come to find out only a dealer can read VSC/Trac control trouble codes. Since I only need to clear the codes I wanted to see if there was some secret way to clear the warning lights before end up paying a dealer. Battery disconnect didn't work, OBD Reader didn't work either. Any other guess??? Thanks!
Old Aug 28, 2007 | 01:16 AM
06B0X's Avatar
Any ODBII scanner should read your car - while I just got those same codes my scangauge showed P0012
No dealership should charge you to look at the codes especially if your still under warranty.
Read this just in case it's what you have:
http://tijil.org/Scion_TSBs/eg00307.pdf
Old Aug 28, 2007 | 01:04 PM
syring65's Avatar
I think opting for the cheaper trouble code reader is the reason it won't read any codes for the VSC. I guess I will bite the bullet and bring it in and mark it down as lesson learned, "if it ain't broke, don't fix it!" Thanks!
Old Aug 29, 2007 | 01:04 AM
jerbear923's Avatar
no joke dude i had those lights come on i took it into the dealer and it was my gas cap, not even kidding i felt like a morron.
evolving_machine
Oct 21, 2023 01:16 PM
daniinpitt
Apr 4, 2015 08:07 PM
toyotaisme
Jan 10, 2015 10:24 PM
