Headlight Question
Old Aug 29, 2007 | 12:14 AM
rukkshun's Avatar
Default Headlight Question
I'm trying to replace my headlight (06) TC - Will I have to remove the front bumper?
Old Aug 29, 2007 | 12:17 AM
scioncraze05's Avatar
yes you do. Thats the only way to remove the headlights.
Old Aug 29, 2007 | 12:38 AM
rukkshun's Avatar
ok thanks
Old Apr 1, 2008 | 03:50 PM
clipp112's Avatar
Default help
help i was changing my left turn signal bulb and it poped out and now its just laying inside the turn signal housing hopw can i get it out help please!!!!!!!!!!!!
Old Apr 1, 2008 | 03:51 PM
pudgy1's Avatar
woah that sucks. umm if you have forceps you can try to pull it out through the hole
Old Apr 1, 2008 | 03:56 PM
milkman713's Avatar
maybe some tape or something sticky on a string or stick to get it attached and pulled out. if not remove the whole head light
Old Apr 1, 2008 | 05:31 PM
clipp112's Avatar
ya when i close th ehood it popped out and now it is on the ground of the headlight???how do u take the left headlight off or i need to take off the plastic part to get in there any ideas??????????????
Old Apr 1, 2008 | 05:35 PM
kiss_tc's Avatar
this also happened to me... i took a long pair of pliers... put some tacky stuff on each end... reached in, squeezed, and pulled... it only took me about 45 minutes... haha.. good luck!
Old Apr 1, 2008 | 06:41 PM
clipp112's Avatar
did u go through the turn signal hole socket because what happened was that the bulb was in the turn signal and when i shut the hood it popped down into the lower part of the headlight??????????
Old Apr 1, 2008 | 07:44 PM
pudgy1's Avatar
where did it fall??? the turn signal has its own small compartment that isnt that big so you should be able to just take out the bulb harness and then use forceps or pliers to pull it out. this should work unless youre talking about the sidemarker on the headlight
Old Apr 1, 2008 | 07:45 PM
HR_Guy's Avatar
I've done this before. Just put some tape on the end of a pen and pick it out.
Old Apr 2, 2008 | 05:09 AM
clipp112's Avatar
its not in the turn signal housing now it popped out when i shut the trunk so now its layinging on the floor of the headlight unit???????????
Old Apr 2, 2008 | 05:23 AM
SquallLHeart's Avatar
take the headlight off the car then.
Old Apr 2, 2008 | 06:04 AM
pudgy1's Avatar
to be honest dude i dont know which one youre talking about, is it the actual turn signal that's right next to the grill?? but either way youll have to take off the headlight
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
