alphawerks header question..
Old Aug 30, 2007 | 11:56 PM
iamjeff6's Avatar
Scion Noics
Default alphawerks header question..
i just bought one off of a SL member and he said that you cannot use the oem brackets..
is this correct, and if so whats the fix/what do you use
Old Aug 31, 2007 | 12:19 AM
Scott8's Avatar
I thought alphawerks used the oem mounting brackets for the header. my old one did.
Old Aug 31, 2007 | 12:21 AM
SquallLHeart's Avatar
for maybe like the heat shield? maybe he means?
you can't reinstall your heat shield..
Old Aug 31, 2007 | 12:23 AM
Scott8's Avatar
the stock header has the 2 bolts that hold it to the motor block. the alphawerks should have the same thing as the oem header to mount it.
Old Aug 31, 2007 | 12:26 AM
iamjeff6's Avatar
Scion Noics
k was just wondering because i didnt know
thanks
Old Aug 31, 2007 | 03:34 AM
Sleep3r's Avatar
hey if you cant get it on then you can always use a engine torque damper to reduce the motor from shaking crazy.
but as far as there being no bracket for support, i was rolling around with no issues
dont worry about it
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
stayintrucha
Regional - Pacific South
Aug 27, 2015 05:01 PM
