installed anzos today but wtf
Old Sep 5, 2007 | 03:44 AM
FlintC's Avatar
Default installed anzos today but wtf
ok ive searched for over an hour and couldnt find the thread i thought this was in, i saw the other one about the guy having fuse problems but this is another problem. ok i installed the anzos/eagle eyes today and the left one works perfectly fine, the right one however blinks really fast as if a bulb is blown. i know it does so bc it is sensing less resistance across the circuit somewhere causing it to blink fast, but i dont know why. its dark out but i got a flash light and went out and was tuggin on some wires and noticed there is a ground wire with the female end of a connector on it... im like wtf, how didnt i see this b4... but yet, nothing to connect it to? i didnt even look to see if it was on the left side yet, but its working fine... im somewhat confused. any clues on wtf is goin on? and whats that ground suppossed to connect to? its dark out like i said, so i really cant troubleshoot, and ive search... and nothing.
Old Sep 5, 2007 | 04:03 AM
FlintC's Avatar
so i did some more searching and believe i found the problem. im goin to try and flip the connections tomorrow on the passenger side and see if that takes care of it. ill bump if not. thanks anyways
Old Sep 5, 2007 | 04:11 AM
theSciontologist's Avatar
i believe you have a blown fuse. we installed a different set of tails and they flipped out like this so check your fuses.
Old Sep 5, 2007 | 04:36 PM
FlintC's Avatar
still cant figure it out. flipped the connectors like suggested and it still does it. what fuse? any other suggestions? where do i need to ground that wire to?
Old Sep 6, 2007 | 01:33 PM
FlintC's Avatar
bump...?
Old Sep 6, 2007 | 03:30 PM
fuses in the fuse box or under the dash. get your manual and check which fuse is the fuse for the turn signals and change it out. trust me.
YooItsJay
Dec 2, 2015 08:13 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
TheTripleC
Jan 4, 2015 06:46 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
