Why does my BRAKE sign come up sometimes?
Old Sep 5, 2007 | 12:12 PM
elite-fusion's Avatar
Default Why does my BRAKE sign come up sometimes?
Hey, i have a question, i recently started noticing that the car gets the Brake light on sometime when i floor the car, and than goes away after a few seconds? my e-brake is fully down, i start driving fine, but sometimes it comes up for a few seconds and goes away? any ideas guys? the car has 33k on it, its on 05 if that helps at all?
please help lol
Old Sep 5, 2007 | 01:55 PM
MrScion07's Avatar
u do any brake work lately? Fluid might b low sounds like it sloshing around in there and the light is comin on and off
Old Sep 5, 2007 | 02:17 PM
oh alright maybe, honestly i dont know much about brake fluid and stuff like that, stupid question, but you think you might be able to tell me wats the name of the fluid meaning like what brand is best for it, and where would i pour it in lol im a n00b
Old Sep 5, 2007 | 02:20 PM
dfwaltima's Avatar
brake light is coming on more than likely becuase your front brakes pads are low on the lining.
Old Sep 5, 2007 | 02:25 PM
ye but it comes on for a split second and turns off, and only when i floor it i think or come to a short stop quickly, so idk :-/
Old Sep 5, 2007 | 02:37 PM
draxcaliber's Avatar
yeah, you need new brake pads. the car notices that it takes more brake fluid to compress the pads to the rotors, and tells you that you need new brake pads.
Old Sep 5, 2007 | 03:00 PM
so what do i need to change? brake pads? fluid? or both?
and what are the best brands for break pads? is there anything special about these or any body shop will have break pads? how much are they?
me = n00b ... sorry lol
Old Sep 5, 2007 | 03:54 PM
raytrix's Avatar
its your brake fluid.
Same thing happen to me.
Get the required brake fluid and add some to the brake fluid tank.
And if you can check your brake pads also.
Old Sep 5, 2007 | 04:05 PM
just get the stoptech stage 1 kit. new front and rear pads, ss brake lines and dot 4 brake fluid. everything you could possibly need.
Old Sep 5, 2007 | 04:25 PM
and how much for all those things?
Old Sep 5, 2007 | 04:27 PM
http://www.dezod.com/pd_stoptech_stage.cfm
279.00 shipped
Old Sep 5, 2007 | 07:39 PM
engifineer's Avatar
To clarify, the brake light comes on because of either pressure issues or low brake fluid. IT just happens that when the pads are worn enough the fluid goes down and causes the light to come on. it is not a brake wear indicator, it is a brake system issue indicator. IF you have uneven pressure due to a leaky caliper it will also come on.
Old Sep 5, 2007 | 08:16 PM
alright thanks guys, ill change my brake pads, and the fluid
Old Sep 5, 2007 | 08:35 PM
engifineer's Avatar
Well you really only need to change the pads... and may not for a while if they are not too worn. New fluid, ss lines, etc are not needed. SS lines will improve pedal feel but will do nothing to make the car stop any better. The stock fluid will do you just fine as well unless you are road racing and risk overheating the brakes. Personally I would just change the pads. I run stock brakes other than the pads and autox mine. I cant complain at all about the brakes.
Old Sep 6, 2007 | 02:19 PM
well my pads squeek a bit here and there so i guess i need to get them changed, and i noticed yesturday, that only when i slow down and let go of brake and floor the car, pedal to the metal, only than it turns on and off, so maybe it is just fluid thats splashing around and at one point when i floor it it just splashes the other way away from the sensor so it ends up coming on, what do you guys think?
Old Sep 6, 2007 | 08:41 PM
engifineer's Avatar
I have seen brand new pads squeal to no end. Take them off and look at them to see if they are worn.
As they wear, the fluid level drops. If is low and sloshes around enough the dummy light will flash.
gqdabien
Oct 8, 2015 05:36 PM
wayneside
Regional - Southeast
Sep 23, 2015 10:42 AM
wayneside
Regional - Pacific Northwest
Sep 23, 2015 10:29 AM
DannyBoy65
Sep 21, 2015 06:23 PM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
