Antifouler
Old Sep 10, 2007 | 06:33 AM
lilaznjdawg's Avatar
Default Antifouler
is there anywhere to still buy those or anything that gets rid of the cel light on an aftermarket header or turbo.?
Old Sep 10, 2007 | 07:12 AM
Dakine's Avatar
Concept in Motion Crew
get the scangauge II. i think those deleted codes or CEL.
Old Sep 10, 2007 | 03:55 PM
Sleep3r's Avatar
local auto store, HELP brand sprak plug antifoulers part # 42002
Old Sep 10, 2007 | 05:03 PM
theslayer's Avatar
interesting
Old Sep 10, 2007 | 05:23 PM
powerofSHN's Avatar
Team Hamster
Per the header DIY in the tech section (I followed it yesterday when installing my Strup header and so far so good):
Originally Posted by Kaeon
*Note* The DC Header is known to make the 'check engine' light pop on, But no worries for $3.00 at your local Autozone Or Pep Boys you can fix this.
You will need a set of Spark Plug Anti-Foul's they are 18mm HELP! brand Part#42002 or 42009.
You will need to drill out a 1/2" hole in one of the Anti-Foul's
Unbolt your 2nd O2 sensor *NOT THE ONE ON THE HEADER, THE ONE ON THE S PIPE*
(I would spray a little WD40 on this o2 as well before removing)
Now screw on the Anti-Foul with the 1/2" hole on top of the regular one and then screw it into the hole for the 02.
Screw the 02 into the Anti-Fouler's tighten everything up, Then disconnect the (-) Battery terminal for about 1 minute.
And BAM no CEL.
~ Kaeon
Old Sep 10, 2007 | 09:30 PM
what is the scan guage 2. and how much is it?
Old Sep 10, 2007 | 11:17 PM
boostaddict's Avatar
autozone might sell somethin diff but i got from Mac tools (this is the only thing i bought from them and i like it) its a small hand held scanner for 60 bucks its great clears codes reads them and some freeze frame data. i use it when our shop scanners are tied up or i just have a non toyota car cuz the toyota scanner takes forever to scan a non toyota
Old Sep 11, 2007 | 09:55 PM
so u bought the scanner from autozone..? scannner have a name?
theracingrhino
Feb 13, 2015 09:49 PM
senseiturtle
Oct 6, 2013 02:03 PM
DirtBagTC
Jan 14, 2010 12:24 AM
SlimJim07
Dec 5, 2008 06:47 PM
Wan
Apr 29, 2007 10:45 PM
