One Sunroof Issue: Fix
Old Sep 11, 2007 | 03:02 AM
engifineer's Avatar
Default One Sunroof Issue: Fix
This pertains to one issue I have heard some complain of before. I recently started getting a lot of wind noise around the sunroof, and then a loud whistle and more wind noise (Especially if I opened the sunroof and then closed it while driving). The noise comes from the seal towards the back portion of the glass. Upon more inspection, the glass will seem to have play in it when closed, so if you push it down in back, the noise will go away, but even slamming the door will cause the glass to push up a tad.
The fix may not be blindingly apparent up front, but to fix it you have to initialize the sunroof. Now, the battery cable may not have been removed, so they dont need to be initialized, so you have to force the matter by leaving the negative battery cable off for a few minutes, reconnecting and then initialize the sunroof. It will re-learn its fully closed position. For some reason over time, it lost its brain a bit
The fix makes perfect since (especially since I designed a jam protection circuit for my car back in college, that works in a very similar manner as this one), due to jam protection and the way it works off of motor load, it needs to know the position for fully closed to operate properly. If this is lost or off a bit, the window will never close fully, even though the auto functions work and the windows dont need to be reset. However, ignoring my own motto of keeping it simple, I poked around and adjusted on the glass positioning first before thinking about the memory
Old Sep 11, 2007 | 03:14 AM
lil_will's Avatar
ScionERA
I will have to try this. Thanks for another helpful post engifineer!
Old Apr 2, 2008 | 03:44 PM
rjj130's Avatar
Hey, not to bring a topic back from death, but I have been noticing the same issue with my sunroof as of late. I'll have to give this a try.
I guess it's not possible to reset the sunroof without disconnecting the negative?
Thanks for the tip!
Old Apr 2, 2008 | 04:27 PM
engifineer's Avatar
Not that I know of. If it has been initialized since the power was last reset, then it wont do it again.
No problem bringing it back up. I was actually hoping someone would sticky it so it would be visible to those with this issue.
Old Apr 2, 2008 | 07:31 PM
audioandy's Avatar
if you pull the main fuse that controls the sunroof and window memory it should be the same thing as disconnecting the battery.
Old Apr 3, 2008 | 03:45 AM
B_Izzle's Avatar
my sunroof started whistling at one point, and it was because of the plastic strip that sits along the front of the wind deflector panel (or basically, its the plastic strip that sits between the top of the windshield and the roof). Anyways, it start to pop up, and a quick firm press down to secure the plastic strip fixed all the whistling from the roof.
now if someone has any fix for the creaking noises coming from the roof, then I'd be much obliged.
Old Apr 3, 2008 | 03:59 AM
Franktc's Avatar
Well this zombie topic is helpful. Glad it was brought up cuz I just started having this problemo. I thought it might have something to do with my seals or something.
Now what main fuse controls the sunroof and window memory?
Spitfire23
Scion tC 1G ICE & Interior
Sep 8, 2015 03:31 AM
5N1PE5
Aug 3, 2015 11:25 AM
Scionxa180
Jul 31, 2015 03:47 AM
sgetchius143
Jul 28, 2015 09:55 PM
TOOSLOW
Jul 25, 2015 05:19 PM
