how do i get that stupid tire pressure light to turn off..
Old Sep 12, 2007 | 07:02 AM
unsungfate's Avatar
Default how do i get that stupid tire pressure light to turn off..
first of i know where the reset switch is and that isn't the problem...
i recently started using bigger tires, as in 225s instead of 215s. the tire pressures for all 4 tires are right on, but the tire pressure light keeps coming back on, and everytimne i check the tire pressures, nothing changed.. do you guys think its because of the bigger tires?? and what can i do to make it stop coming back on?
its annoying me
Old Sep 12, 2007 | 07:05 AM
xIxAMxHOLLYWOODx's Avatar
what year is your car? who changed the tires?
Old Sep 12, 2007 | 07:10 AM
unsungfate's Avatar
06' and some beaners at some tire shop....
Old Sep 12, 2007 | 07:11 AM
AzNpNoY74's Avatar
U sure they placed the tire pressure sensor on the new wheels?
Old Sep 12, 2007 | 07:13 AM
You sure they didnt take the sensors out? did you watch them? Im not 100% that the '06 uses the sensors, but I believe it does...
Old Sep 12, 2007 | 07:14 AM
unsungfate's Avatar
uhoh... i don't think so... are the tire sensors those little clips that are on the rims?? if so.. no they didn't
Old Sep 12, 2007 | 07:17 AM
no, they are INSIDE the rim. They attach to the valve stem. It looks like a plastic tumor...
Old Sep 12, 2007 | 07:23 AM
unsungfate's Avatar
oh! then i don't know, i can't imagine why thtey wouldn't though, all i know is the warning light is annoying
Old Sep 12, 2007 | 07:28 AM
Ive seen weirder things happen! those sensors are valuable!
Old Sep 12, 2007 | 07:37 AM
unsungfate's Avatar
well i'll be damned... how can i check if they are there or not?
Old Sep 12, 2007 | 07:42 AM
know anyone that works at a tire shop? I would look in to making sure the '06's have sensors to begin with. If they do, take it to a trusted tire shop, and see if they are there. you're rolling on the same rims that came with your car right?
Old Sep 12, 2007 | 07:48 AM
suvving's Avatar
hey does anyone know if there's a way to just disable (turn off) the tire sensor light? I'm using different wheels (I have my stock wheels with the sensors in the garage), and I get annoyed at seeing that damn light on the dash.
Old Sep 12, 2007 | 07:56 AM
unsungfate's Avatar
yeah same stock rims
Old Sep 12, 2007 | 08:02 AM
ummm, not sure on disabling it...
maybe just unsoldering the LED that lights up when the sensor is tripped?
Old Sep 12, 2007 | 08:05 AM
SquallLHeart's Avatar
he says he has an '06..
'06's don't have tire pressure sensors.... they are run off by ABS..
you need to reset the tire pressure system.. and reinitialize it... check your pressures.. and press and HOLD the reset button until the light blinks 3 times.
Old Sep 12, 2007 | 08:14 AM
unsungfate's Avatar
the tire pressure light? hmm sounds like a plan
Old Sep 12, 2007 | 03:13 PM
apautogarage's Avatar
Just take out the bulb! lol
Old Sep 12, 2007 | 05:08 PM
See, thats what I thought, but wasnt sure. I know my '05 doesnt have sensors, and I thought I heard the same for the '06. But I wasnt positive. SO yea, make sure you double check that the pressures are correct, and then press and HOLD the button.
There isnt a "bulb"...
Old Sep 12, 2007 | 05:33 PM
Then how the heck does it light up? Take off the cluster part off and remove the little bulb.
Old Sep 12, 2007 | 05:43 PM
emptystreets130's Avatar
they're not bulbs. leds. you can't just yank them. There is a section in the owners manual that will tell you how to reset the light.
