how do i get that stupid tire pressure light to turn off..
first of i know where the reset switch is and that isn't the problem...
i recently started using bigger tires, as in 225s instead of 215s. the tire pressures for all 4 tires are right on, but the tire pressure light keeps coming back on, and everytimne i check the tire pressures, nothing changed.. do you guys think its because of the bigger tires?? and what can i do to make it stop coming back on?
its annoying me
its annoying me
know anyone that works at a tire shop? I would look in to making sure the '06's have sensors to begin with. If they do, take it to a trusted tire shop, and see if they are there. you're rolling on the same rims that came with your car right?
hey does anyone know if there's a way to just disable (turn off) the tire sensor light? I'm using different wheels (I have my stock wheels with the sensors in the garage), and I get annoyed at seeing that damn light on the dash.
he says he has an '06..
'06's don't have tire pressure sensors.... they are run off by ABS..
you need to reset the tire pressure system.. and reinitialize it... check your pressures.. and press and HOLD the reset button until the light blinks 3 times.
Originally Posted by apautogarage
Just take out the bulb! lol
There isnt a "bulb"...
