Antenna
Old Sep 15, 2007 | 12:54 AM
Schmohey's Avatar
Default Antenna
I want to know how is the long rubber antenna attached to the car's roof? I'm trying to determine whether it fell off while I was driving or someone stole it.
Where can I find a replacement antenna?
Old Sep 15, 2007 | 02:15 AM
jimmbomb's Avatar
ok.. from the tip of the antenna down to the sheet metal roof... about 8 inches... jh
Old Sep 15, 2007 | 02:37 AM
Schmohey's Avatar
Actually, I want to know how is the antenna attached to the base? Is it screwed on or is it fixed to the base with a pivot on the bottom?
Old Sep 15, 2007 | 02:53 AM
jimmbomb's Avatar
oHHHHHHHHHHHHhhhhhhhh ok.. my bad... sorrry........... i read it wrong......... hhhhmmm lemme get the flash light out... be right back.......
Ok I looked at the pivot point... NO fasteneers visable.. then looked above the pivot point going up the antenna & saw a seam... So I grabbbed the antenna & 'unscrewed'. Well I unscrewed the antenna all the way off! Now the pivot point remained on the car with the 'male' threaded end exposed. Inside the removed antenna shaft is a threaded 'female' end....
Hope this answeres your question.... jh
Old Sep 15, 2007 | 05:01 AM
Schmohey's Avatar
Not a problem. Thanks for checking it out.
I can confirm that some @#$#@$#@ stole my antenna!
I always get confused with the male/female ends. Would the antenna shaft's thread look something like this? Also, what's a good replacement for my missing antenna shaft?
Found it here:
Is it even worth $50???Link to Antenna
Old Sep 15, 2007 | 07:12 AM
boooosty's Avatar
1UP Crew
idk, if you listen to the radio, then I guess you have no other choice but to buy the $50 antenna.
-captain obvious
Old Sep 15, 2007 | 08:29 AM
rsw1124's Avatar
http://www.sigmaautomotive.com/FoliaTec/antenna.php
I have the Shark fin on bottom of page. Had to wait but worth it. EXACT paint job and clear coated also.
Old Sep 17, 2007 | 02:00 PM
tanker's Avatar
I have a shark fin on mine. If you want I will send you mine if you pay shipping. Hit me at tank@tankspaintball.com.
Old Sep 18, 2007 | 05:53 PM
xhrhx15x's Avatar
they matched the color for you? thats awesome. i'm gonna look into getting one now.
Old Sep 18, 2007 | 06:47 PM
rsw1124's Avatar
They match the color specifically based on the paint code of the vehicle. Make sure you checka nd get it here if you do not have hte code. I believe codes are in a sticky note above here. Here is a close up shot to help you decide for sure...
Old Sep 18, 2007 | 07:42 PM
Schmohey's Avatar
Looks pretty tight. How was the installation? The website was a bit vague on the installation.
Old Oct 11, 2007 | 05:46 PM
ScionicXTC's Avatar
I just got the same one straight from VG at SharkfinAntenna.com at the lowest price I've seen.
Click here for pics & install summary
Old Oct 12, 2007 | 05:07 AM
matt311's Avatar
I like how he gets the male/female ends mixed up.... weird huh?...
Old Oct 12, 2007 | 01:03 PM
xhrhx15x's Avatar
Thats why i prefer to deal with 2 male ends...less confusion.
Old Oct 12, 2007 | 03:18 PM
uberspeed's Avatar
Funny. I'll stick to the arrangement I have, 1 male to 2 female ends.
Old Oct 12, 2007 | 03:30 PM
matt311's Avatar
^^ Thats what happens when your antenna is too long for one female end.
Old Oct 12, 2007 | 04:17 PM
uberspeed's Avatar
And/Or when you get lucky enough to connect with a female end that doesn't mind sharing and has trouble dealing with your... "exuberance" shall we say. Appetite for life?
pjl52
Aug 13, 2015 02:38 PM
Charlesatthedisco1
Jun 20, 2015 06:43 PM
djmike113
Apr 7, 2015 12:43 AM
Socialdisorder
Apr 3, 2015 01:35 AM
Kata
Mar 2, 2015 10:46 PM
