2004-2006.5 [NCP61]
Firming up the xa
Old Sep 15, 2007 | 08:15 PM
cobb's Avatar
Default Firming up the xa
I got the hos shock tower brace and rear sway bar. It has made some difference, however its still flexing and swaying when taking corners as the road weaves doing 90 down the interstate from a mid left to right or vice versa. I was looking at some other posts and was wondering about a few different products.
tan front brace http://www.optionsauto.com/prodinfo....er=TNB-TUB099F
The front brace looks pretty straight forward and bolts on, however I am a bit concerned about the rear one. http://www.optionsauto.com/prodinfo....er=TNB-TUB099R
Appears that it goes in place or with the sway bar as it looks like it bolts to the car by the gas tank area then the rear swing axles. Is that correct? How will this effect speed bump travel and a hos sway bar?
Also been looking at the xb frame braces. http://www.optionsauto.com/prodinfo....er=TP-14013201 and http://www.optionsauto.com/prodinfo....er=TP-14013200
Ive read about a trd brace, however a google search just turns out reviews about the scion xa. Thanks for any help. Maybe I need a wing vs bracing for highway use?
Old Sep 15, 2007 | 08:20 PM
jct's Avatar
jct
51503-NP100 is that part number for the rear lower frame brace for the TRD unit even though its for the vitz it will fit our cars perfectly
or for the part number for our car is 51503-NP600
Old Sep 15, 2007 | 08:32 PM
987KEITH's Avatar
Try the Megan Racing H-Brace! I love it!
My installed pix - https://www.scionlife.com/forums/viewtopic.php?t=192377
Old Sep 15, 2007 | 08:33 PM
987KEITH's Avatar
EDIT: Not sure if it fits the xA, sorry!!!
Old Sep 15, 2007 | 08:39 PM
jct's Avatar
jct
it'll fit
Old Sep 16, 2007 | 01:53 AM
cobb's Avatar
Thanks Keith, that looks nice.
Maybe I am thinking of something else, but the sway bar I bought seems a bit disconnected. I mean the rear sway bar on my mercedes mounts to the bottom of the trunk with two 2 mounts and connects to the axle ends by 2 small links. This way it allows the whole two wheels to move up and down together for a speed bump, but if they moved diferently, it cause the rear of the car to move some and limited their motion. This sway bar for the scion just mounts to the botom of each axle end and no pivot point to the bottom of the car.
Old Sep 17, 2007 | 10:48 AM
sotied's Avatar
Default makes a difference?
Does this really help that much?
My factory xA seems fine.
Old Sep 17, 2007 | 02:01 PM
Dispatcher138's Avatar
http://www.sfxperformance.com/parts/TABTUB099R.htm
Better picture of the rear one.
Old Sep 17, 2007 | 02:49 PM
badbasic's Avatar
from ur profile pics it looks like ur still running stock springs and tires. replacing those will help as well
Old Sep 18, 2007 | 05:52 AM
bear454's Avatar
I have the Hotchkis strut tower brace https://www.scionlife.com/parts/?part=10125
and TRD springs - that alone was a night & day difference from stock. I'm patiently waiting for my struts to wear out to justify getting the TRD set.
yupinmytC
22
Jul 27, 2024 07:08 PM
RS2Blitz
Jan 15, 2016 09:42 PM
NonStopTuning
Jun 29, 2015 07:42 PM
