Taller tires for snow ?
Old Sep 20, 2007 | 02:51 AM
tCscotty's Avatar
Default Taller tires for snow ?
So, I'm going back to stock for the winter. No more plowing snow for this winter. Never make that mistake again.
Besides going to stock ride height. I was thinking about going with a taller tire to gain a bit more clearance. Maybe a 65 or even 70 series tire.
I was having problems with wheel well clearance with the stock size tire and being lowered. Will I run into issues with this route, too? I figure the 65 wont be to bad, but I'm not sure if the 70 will. Anyone running or plan on running this setup.
Old Sep 20, 2007 | 03:55 AM
hotbox05's Avatar
your were having problem with stock diameter? how low were you? 5 inches ?
the 70 should fit but may rub at full lock.
Old Sep 21, 2007 | 04:27 AM
tCscotty's Avatar
Not having problems with tire clearance as in rubbing the inner fender with the tire. I ment with snow getting compacted and not having enough space for it to get out. I was on s-techs during the winter and the snow would just build up to the point where I would have almost no travel.
I will be at stock ride height when running these tires. I'm just concerned that I'll run into the same problem if I go with a 70 series tire. Sorry if I wasn't clear with that.
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
Jan 18, 2016 08:41 PM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
3panther
Jan 29, 2015 09:59 PM
BlueBox
14
Jan 15, 2004 01:08 PM
