AVIC-D2
Old Sep 28, 2007 | 08:53 PM
nauticac's Avatar
Default AVIC-D2
When performing the bypass on the avic-d2, upon grounding the parking brake wire, will the "ebrake" light light up on the instrument cluster? That would be annoying. If so, is there any way around that?
Old Sep 28, 2007 | 08:58 PM
Dakine's Avatar
Concept in Motion Crew
the ebrake will not light up. only purpose of the bypass is for the dvd's
Old Sep 28, 2007 | 09:59 PM
tweetertc's Avatar
you ground the ebrake wire on the back of the unit... not the factory wiring... hopefully this will clarify...
Old Sep 28, 2007 | 10:15 PM
nauticac's Avatar
Ohhhhh thanks for clarifying. I was under the assumption that I was to ground a factory wire. Thanks again.
Old Oct 16, 2007 | 04:54 AM
nauticac's Avatar
When re-pinning the harness with the new wire..how do you ground it if you have to plug the harness back into the unit?
Old Oct 16, 2007 | 05:42 AM
tweetertc's Avatar
just with the regular ground in the after market harness...
Old Oct 17, 2007 | 05:06 AM
nauticac's Avatar
what do you mean tweeter? It's a little unclear to me because I've been out of town and haven't had a chance to look at the unit yet. I just want to make sure I know what I'm doing when the time comes very shortly.
Old Oct 18, 2007 | 04:33 AM
tweetertc's Avatar
alright... here it goes...
you will re-pin the power and speaker harness in the only empty spot... now that wire.... your original ground and lt. green ebrake wire you will ground out all together to the car harness... does that make sense.... its does in my head but its late and i just worked a 14 hour day...
Old Oct 18, 2007 | 05:55 PM
nauticac's Avatar
I think so. Thanks for explaining that furthur to me. I'll take a look at it this weekend.
Old Oct 19, 2007 | 07:34 PM
nauticac's Avatar
So I just ran into something unexpected, the back of my unit doesn't have video inputs..meaning no plugs for Red, Yellow, White. I have the AVIC-D2. I was under the assumption those input plugs would be there. How do I get a video signal?
Old Oct 20, 2007 | 12:53 AM
tweetertc's Avatar
there should be another harness that should have came with the unit... it has vid/audio in.. vid/audio out.. ect...
if you dont have it you can try getting it from a pioneer dealer... bby and cc are out automatically... they suck at stuff like that
Old Oct 20, 2007 | 12:57 AM
nauticac's Avatar
you've been a huge help so far. I'll have to run up to my apt. at school tomorrow and check the original packaging for that harness. Thanks again tweeter.
Old Oct 21, 2007 | 06:47 PM
tweetertc's Avatar
yeah no prob bro...
thats what i check the forums pretty regularly for...
Old Nov 12, 2007 | 04:54 AM
davedavetC's Avatar
so way, explain it again lol. i read it a few times and im getting the D2 sometime this week and i wanna ground it so i can watch movies when im moving. if its possible could you take pics of what your talkin about?
Old Nov 12, 2007 | 04:59 AM
MicE's Avatar
i have a D2 connected to my valor Dvd and i bypassed it at the stereo store.. the charged like 40 bux.. now i can drive and watch MOVIES!! i barely use this feature tho.. I heard for D1 u can use the brake bypass but D2 is different.. i don't think the E brake will allow you to bypass the D2..
Old Nov 12, 2007 | 08:48 PM
tweetertc's Avatar
alright...
here ya.. there is the one harness that comes with the unit... and power harness... it has your acc(red) Power (yellow) Ground (black) speaker wires (purple, green, white, gray) there will be one empty pin.. you need to pull a pin out of another pioneer harness.. (a lot of guys just pull the mute wire out of the secondary harness.. the one with the rca cables...) put in there then ground out that wire with the radio ground as well as the ebrake wire (lt green)
i think thats pretty clear... i hope it helps...
Old Nov 13, 2007 | 03:08 AM
davedavetC's Avatar
lol ill try, ill have to have the harness in my hands
Old Nov 15, 2007 | 04:27 AM
davedavetC's Avatar
ok i have a long green wire that says parking brake ground, is that the wire i need to tap into some where to bypass this ****? where do i tap it. im lost. and theres a pink speed sensor wire, where is that attached to. this is so much more complicated tehn a regular stereo
Old Nov 15, 2007 | 06:23 PM
davedavetC's Avatar
bump
minter66
Scion tC 1G ICE & Interior
13
Feb 25, 2010 01:31 PM
math_man_tation
Aug 26, 2009 02:55 AM
gicode0823
Jul 29, 2007 08:48 AM
Daurigon
Dec 1, 2006 05:08 AM
josh1611
Nov 15, 2006 10:01 PM
