Afetrmarket downpipe
Old Sep 28, 2007 | 10:22 PM
tc1stgen's Avatar
Default Afetrmarket downpipe
Ok so as some of you know, I recently put on a Megan header that changed my beautiful exhaust tone to crap. Today it went into the shop and got a resonator welded onto the mid pipe that completely took away the rasp. I am curious about a couple of things however. First because I opened up the header and my piping is 2.5", would I benefit from upgrading the down pipe as well to keep the air flow an even 2.5"? And if I do decide to upgrade this piece, will it create rasp all over again?
Old Sep 28, 2007 | 11:22 PM
Mid_Life_tC-risis's Avatar
Since you are naturally-aspirated you're talking about the S-pipe, down pipe is a turbo exhaust pipe. And because you are not turbo you don't need a full 2.5" exhaust. People forget this engine is just a Camry 4-banger. 2.25" is the ideal pipe size for aftermarket exhaust on a n/a tC.
Although the inside diameter of the S-pipe actually necks down to about 2" at one point, it's still just an empty pipe. After you have replaced the restrictive stock muffler & exhaust manifold you have maxed out your exhaust HP gains.
Spending $150-200 on a 2.5" S-pipe MAY gain you 1-2whp (equivalent of a dyno error) at high RPM's but it will surely ruin your low-end torque. At the tC's relatively low horsepower / exhaust flow the increase in pipe area from 2" to 2.5" (or even from 2.25" to 2.5") is dramatic enough to kill exhaust scavenging in the low end.
Old Sep 28, 2007 | 11:25 PM
tc1stgen's Avatar
Well I do have intentions of going turbo in the nearby future. I only put a I/H/E on because I needed something. Right now I don't have the cash to spend on Turbo but I figured I would ask.
Old Sep 28, 2007 | 11:36 PM
Duartizzle's Avatar
get a 2.25 inch pipe. do they make that? or do they only come in 2.5?
SloTC1
Aug 16, 2018 02:45 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
scion86
Jul 6, 2015 03:27 PM
