Question regarding brakes
Old Oct 7, 2007 | 03:09 PM
socal_showdown's Avatar
Default Question regarding brakes
I recently installed my own EBC green stuff front and rear brake pads and left the stock rotors. They have about 35k miles on them. I have been waiting for the new brakes to properly brake in but they still squeal quite a bit and make some nasty noises when they get very hot. I used the spray-on brake dampener from Toyota on the brake pad shims and installed everything properly (i think!).
Yesterday I got home from a long drive (lots of city driving and braking) and started to wash my car 5-10 minutes after I parked. When my rotors / brakes got wet they STEAMED up and smelled pretty bad. Is this normal for a long drive? I've never noticed it before. I can't figure out why my brake pads won't wear in and be silent
Any help please!
Old Oct 7, 2007 | 08:59 PM
tc913's Avatar
Never....and I say Never wash your car after you have driven it for that long. Always wash your car before any driving because the cold water can cause you to warp your brake rotors and will misshape your pads as well.
Old Oct 7, 2007 | 09:02 PM
Resu's Avatar
With the more aggressive pads you're could get a a little squel, but not as much as you're describing.
How many miles do you have on the new EBC greens? Were you saying that you have 35k on them?
Old Oct 7, 2007 | 09:28 PM
At 35k miles I changed the pads and left the stock rotors. Replaced the stock pads with EBC green stuff and I am at about 39k miles right now.
And I will never wash my car after driving again! Sorry!
Old Oct 8, 2007 | 08:38 AM
sciontc_mich's Avatar
^^^ you're probably fine for the little bit you did, no warping. But yeah keeping that up over time, would warp the rotors..
glad we caught ya before it cost you some $$$ to fix..
the squealing? hmm.. did you break in the pads correctly? did you use light sand paper to lightly rough up the rotor surface before you put on the EBC pads? if not, the material is not transferring to the rotor, since the stock material is on the rotor surface. remove that by using a light grade sandpaper, then break in, i believe your squeal should be gone after that.
Old Oct 8, 2007 | 02:39 PM
Good idea! If it keeps up I'll definitely give it a try.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
