Has someone done this yet???
Old Oct 10, 2007 | 12:27 AM
forpinks's Avatar
Default Has someone done this yet???
Well I've searched... I'm just wondering if someone here actually turboed their tC for the environment's sake?
I'm talking about a low boost recirculated dump pipe and environment friendly pre-cat after first O2 sensor, and a main cat that works so great, it rivals a PZEV vehicle...
You guys might say "turbo tC for the environment?", but as far as I know, turbochargers set at low boost PSI with good cat-cons though will not give as much WHP as "non-catted" setups, will actually be more environment friendly and could make your engine last longer since it burns cleaner and maybe even better MPGs with the right tuning method.
I just want to know if someone here has this setup or are you guys just gonna laugh at me silly?
Old Oct 10, 2007 | 12:34 AM
ignitionr34's Avatar
Old Oct 10, 2007 | 12:43 AM
draxcaliber's Avatar
tree huggers don't drive turbo tc's. they drive hybrids and bio diesels that are turbocharged...
and dammit, what are you doing back? i guess i spoke too soon...curses...
Old Oct 10, 2007 | 12:59 AM
DarthVadertC's Avatar
Old Oct 10, 2007 | 01:03 AM
PAL20G's Avatar
not serious......
Old Oct 10, 2007 | 01:21 AM
scandalous's Avatar
Scion Driven Girls
I recirculated my WG and keep my boost at 7.5psi. I do care about the environment, so I do what I can. Could do more, but, hey, its a turbo!
Old Oct 10, 2007 | 02:50 AM
318_tC's Avatar
____ mine is for the environment, open exhaust shooting flames every shift
Old Oct 10, 2007 | 03:01 AM
shizzzon's Avatar
Hehe, we should put decals on our car stating-
Vet tested, Never approved...
Hmm, environmentally safe rice stickers come to mind...
Old Oct 10, 2007 | 03:07 AM
SickleCell's Avatar
$7,000 on a Granola Turbo or $7,000 extra on a hybrid hmmmmmm. Let me kick myself in the nads and figure it out.
I nailed a butterfly going 90mph, but at least I get 27 mpg.
Old Oct 10, 2007 | 03:34 AM
yamaha16bw's Avatar
Originally Posted by 318_tC
poop mine is for the environment, open exhaust shooting flames every shift
x's 2 haha. I havent had an s-pipe on for about a month.
Old Oct 10, 2007 | 03:35 AM
forpinks's Avatar
I don't wanna drive an automatic to save the environment!
How much of the emissions from a regular single cat turbo tC can I reduce with 2 efficient cat-cons?
Oh, and I already ordered a GReddy turbo kit w/ pkg 2 Megan Racing boost and AFR gauge, HKS SSQ BOV, no exhaust yet, It should arrive thursday, but I'm keeping it in my living room not to be installed till it's time to.
Also, what else do I need to go with the turbo?
Old Oct 10, 2007 | 03:46 AM
deathbyc4's Avatar
if you want to be more environment friendly, why dont you figure out what we need to run E85 ethanol? that way we arent sucking up so much gasoline. just a thought.
Old Oct 10, 2007 | 04:16 AM
kungpaosamuraiii's Avatar
The idea is relatively sound. The compression means the car warms up faster and running hotter usually means more power if wrought from a unit of fuel. Running your cats will keep the SOx and NOx byproducts from hotter combustion to a minimum and finally, turbocharged cars tend to get really good gas mileage at high speeds, that is, 70-90 mph rather than an NA's 65-75 mpg butter zone. But good luck running a 14 afr on a turbocharged non-turbo car. Sure you can run less boost but then you don't get the benefits.
Now, I'm seriously generalizing but, generally speaking, you may as well buy yourself an xA to save the environment. Another option is work on getting the hotter combustion without a turbo. Route a custom intake to breath right over the exhaust header and get a thermostat that'll let your car run on the lunatic fringe of hot coolant temperatures. If you want to keep going, coat every surface that gets hot and use very low weight oil. But by the time you get there, I hope you've already stripped your car of every unnecessary ounce of "dead" weight.
Old Oct 10, 2007 | 04:37 AM
FireStorm's Avatar
x2
Old Oct 10, 2007 | 04:38 AM
SickleCell's Avatar
Vinyl and a cocky attitude. (I'm just playing around)
Old Oct 10, 2007 | 04:42 AM
Ace83's Avatar
Ronin Scion
i told you guys he'll be back..
Forpinks, if you dont know what im talking about some of the the guys here jsut missed you lol.
Old Oct 10, 2007 | 04:50 AM
Ace83's Avatar
Ronin Scion
Good luck on your turbo, install and tune it right and show us your bad ___ car.
And what else do you need? you know what you need..
Old Oct 10, 2007 | 04:56 AM
BlackRose617's Avatar
pave
the
rainforest
Old Oct 10, 2007 | 05:00 AM
forpinks's Avatar
I barely drive my tC now, it has 2100miles and maybe it might change as soon as I install the GReddy kit and have it tuned.
For some reason, I really don't like how the tC handles even with a new rear anti-sway bar set to medium, it still felt like a big wagon and an 07 RAV4 at the same time.
But, really guys, what else do I need for my turbo, is an axle back necessary, 10W30 synthetic oil for the extra load, please tell me if I missed to buy something else?
Once my turbo gets here, I'll check the wastegate if it opens properly and tape the box back and store it a few feet away from my tC : ) to be installed when my friend gets back by February from his temporary transfer at his job...
(OK, I can't weld alright! he does, I have to get my BOV welded by him and I want the oil feed barb welded on too...)
