Anyone Installed A remote Start on 2G???
I am in the midst of installing a remote start on a 2G. However i have been unsuccessful. I have heard rumor of there being a 2nd starter wire and a keysense wire that may need to be wired. Does anyone have any info as to if they are necessary and how they were hooked to the aftermarket remote start unit!
FYI: I am not new to the installs! I have all basic ignition wires connected and tested correctly. Which brings me to my conclusion there is something more!!
ANY HELP IS APPRECIATED!!!
there is a 'sticky' here at the top of this section that has the wires & colors outlined...
https://www.scionlife.com/forums/viewtopic.php?t=180214
good luck.. jh
good luck.. jh
I had remote start installed a few weeks ago. Ended up having a fuse blow and took it back. The install center (which i have had do many installs) was very complete and figured out that they had linked it into the starter wrong. So be careful and make sure you are reading instructions for the 2008, because it IS different.
ok from the starter wire of the alarm...use a diode to hook up to the second starter...so its both hooked up....ive done about 8 of these cars..also my own...no need to hook up keysense wire....
K so that alarm that started this whole thread was scrapped when even the company couldnt figure out what was wrong with it. so now i got a new Viper 791 and well im gonna throw that in saturday...so i ran to the radio shack to pick up a diode.
problem is what volts am i looking for?? they have 1 amp ranging from 50-1000 volts. i did find one 12v but it wasnt 1 amp. so if you could please assist i would appreciate it so i can be prepared for the install!
thanx
thanx
k so i installed the alarm this weekend with much success. everything works minus one major thing. im postin it here hopin someone has the answer.
During remote start the alarm doesnt unlock or lock doors. it still disarms and arms the alarm.
please any assistance is appreciated..
