4 wheel alignment on xB?
Old Oct 13, 2007 | 07:09 AM
bigskyscion's Avatar
Default 4 wheel alignment on xB?
I've looked high and low and can't find the definitive answer...is it necessary to do a four-wheel alignment on a 2005 xB? Or just the front end? Thanks
Old Oct 13, 2007 | 07:13 AM
OldYeller's Avatar
There are really no adjustments on the rear end--or so I have been told. When I got my drop I had an allignment and they adjusted the front but just gave me the measurements on the back.
Old Oct 13, 2007 | 07:39 PM
burstaneurysm's Avatar
Just the front. The only thing you can really adjust on the rear is camber.
Old Oct 13, 2007 | 10:40 PM
swartzautoman's Avatar
no (stock) rear ajustments on the xB1.
the only real way would be with hub shims.
Old Oct 13, 2007 | 11:52 PM
CBSIMONSEZ's Avatar
The only allignment would be if it were in an accident and needed to be brought back to factory specs.
Old Oct 13, 2007 | 11:59 PM
Metro273's Avatar
I work at a dealership and I have full access to a laser alignment machine and there is absolutely no rear alignment on our xBs...
Now of course you can do camber on the rear with a camber shim kit, I think that's what it's called, I'm sure someone will correct me...
Old Oct 14, 2007 | 12:08 AM
sprslug_182's Avatar
The alignment on an xB is called a four wheel thrust alignment. Basically what happens is that the alignment in the front is based off of the alignment in the back, just like a truck or any vehicle with a solid axle or torsion beam suspension. So what happens is, if all of the suspension components in the rear are in great condition and if the torsion beam is not bent, the front suspension with align great, if components in the rear are worn or the torsion beam is bent, the front suspension will never align correctly.
Have you ever seen a truck that looks like it drives kind of sideways? A lot of the time it is because it was hit in the rear or the axle has shifted and it was aligned based on the geometry of the rear suspension.
Hope that helps.
Old Oct 14, 2007 | 01:18 AM
thats what you call "dog walkin"
Old Oct 14, 2007 | 02:32 AM
Old Oct 14, 2007 | 05:01 AM
OldYeller's Avatar
A dog will walk "sideways" sometimes to appear bigger during a confrontation. My little dog does that with our cat when they are playing--it is a very funny sight to see.
Old Oct 14, 2007 | 02:20 PM
CBSIMONSEZ's Avatar
For cars its called " Off Tracking " and like is mentioned it happens from a rear collison and the rear was never set back to specs, or couldnt be set cause the damage was too bad.
Old Oct 14, 2007 | 10:39 PM
Ed's Avatar
Ed
Do you use Hunter machines? I have two 811 systems at work.
If you go into the Winalign "tools and kits" menu it should show a shim for adjusting both rear camber and toe at the same time. I've used it before,it's part # 75800 from Specialty Products.
Old Oct 16, 2007 | 07:35 AM
bB2NER's Avatar
Music City Scions
Almost right. It's Dog- Tracking. Mostly seen on vehicles with leaf springs on the rear that are not adjusted straight.
eatcrispycreme2
Jan 30, 2015 03:42 AM
toyotaisme
Jan 10, 2015 10:24 PM
kleecker
Jan 2, 2015 08:09 PM
minter66
Dec 15, 2014 01:45 PM
JDMxB
13
Dec 23, 2003 04:23 AM
