noise with s-tech
Old Oct 18, 2007 | 03:19 AM
vpfosho6's Avatar
Default noise with s-tech
i just installed my s-techs couple of days ago. everything sounds fine but the front right wheel makes this noise everytime i go over a seed bump. all the other ones are fine.
any idea what is wrong?
Old Oct 18, 2007 | 03:21 AM
pioneer1976's Avatar
well what kind of noise, i would double check that everything is tight.
Old Oct 18, 2007 | 04:44 AM
vpfosho6's Avatar
i did double checked it. we took the springs off. and put it back together. i dono what it is. it sounds when the wheel bounces. but not when i go really really slow over the bumps.
Old Oct 18, 2007 | 05:03 AM
draxcaliber's Avatar
hmmm...check to see if the shock is blown, or if the half shaft is bent.
Old Oct 18, 2007 | 05:22 AM
fujita_TC's Avatar
x2
Old Oct 18, 2007 | 05:36 AM
vpfosho6's Avatar
damnn... i gotta get new shocks then???
Old Oct 19, 2007 | 04:29 AM
HyPnOtIk's Avatar
You could have installed the springs wrong .. Although that is very hard to do it is very possible . if the spring isnt setting right it can make a Clunk noise when you go over certain bumps .
The second alternative is your shock is going bad . Check that also .
Old Oct 19, 2007 | 07:20 AM
DonNguyen's Avatar
did you cut your bump stops as well? could just be bottoming out on the bump stop
Old Oct 19, 2007 | 01:54 PM
vpfosho6's Avatar
we didnt cut any of the bump stops. we just left it as is.
im pretty sure we didnt install it the wrong way because we redid it twice
Old Oct 19, 2007 | 04:11 PM
DonNguyen's Avatar
i think you may just be bottoming out on your bumpstops
Old Oct 21, 2007 | 04:02 PM
torchedbox's Avatar
if thats the case, then wouldn't it do it on all 4? I just put s-techs on my tC and have no problems at all. Car is all stock other than springs.
kb1sxv
Oct 21, 2015 05:00 PM
Klashan
Sep 24, 2015 12:39 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
