How Much $$$$ to lower my tC?
Old Sep 27, 2007 | 03:37 AM
astros15's Avatar
Default How Much $$$$ to lower my tC?
I'm getting 18's on my tC and I'm wondering how much its gonna cost me overall to lower my car enough so it looks good with 18's.
Old Sep 27, 2007 | 03:44 AM
Yanki01's Avatar
depends on what type of drop you want? Im guessing you havent bought springs yet? Call some shops in your area (guessing Houston?) and get some quotes. Check out the suspension section for some pics. I suggest Hotchkis
Old Sep 27, 2007 | 03:56 AM
astros15's Avatar
lets say i get s-techs, would i have to get a camber kit? how much would it all cost?
Old Sep 27, 2007 | 05:50 AM
BZinn1's Avatar
when I was researching cost stechs were like $135-150 and the camber kit was like about that or a bit more......install cost between 200-400........not sure if the camber kit is needed for sure but I think it is to align properly......htechs did not need it just the alignment........so I guess cost could be between 500 and 700 plus alignment for like 70 more.......if you install your self it will be much less.......jsut need a few friends and a spring compressor and a bit of knowledge.......there is a few DIYs in the tech sectin that are really good.......
Old Sep 27, 2007 | 07:49 AM
AzNpNoY74's Avatar
Just some advice if your gonna do it yourself, have air drill and/or breaker bar... they will make your install so much easier... too bad i didn't have either when installing mine... took me and my friends like 3 hours on the front and x hours for the rear
Old Sep 27, 2007 | 02:39 PM
Keeshwah's Avatar
ya find someone who's done it before and it will go real fast. took me forever and I spent more money on it than I had to. You don't really need a spring compressor, just a jack and some stands.
Old Sep 27, 2007 | 06:38 PM
DonNguyen's Avatar
spring compressors make it much less of a pain in the ___....
Old Sep 27, 2007 | 07:47 PM
Keeshwah's Avatar
spring compressors make it much less of a pain in the butt....
i dont have one laying around
Old Sep 27, 2007 | 08:05 PM
astros15's Avatar
so i wont need a camber kit if i get s-techs and drop it 2.4 and 2.0 like everyone does?
Old Sep 27, 2007 | 10:02 PM
Mr_Meaty's Avatar
You can rent a spring compressor from autozone and you get all your money back when you return it.
you should be good with just an allignment.
Old Sep 27, 2007 | 10:31 PM
scionjon's Avatar
Default springs
i dropped my car with the tanabe df210 springs and it look good the ride quality is 10 times better than and the handling is great i paid 130 for the springs and 100 for the installation and it would look perfect with 18"s
Old Sep 27, 2007 | 10:54 PM
astros15's Avatar
so youre saying i dont need a camber kit?
Old Sep 27, 2007 | 11:09 PM
scionjon's Avatar
Default springs
i never used a camber kit since the drop and it drives and looks good the only thing you would need to do is after it settles is to get an alignment and you should be fine
Old Sep 27, 2007 | 11:10 PM
kileil's Avatar
You don't need a camber kit on s-techs. There's enough factory adjustment to get it within 1 degree of stock.
Old Oct 15, 2007 | 05:28 AM
Katoes's Avatar
No camber kit, just lowered my car and it cost me nothing....isn't that nice, thanks to the WRX guys of ATL.
Old Oct 18, 2007 | 07:10 AM
sciLon's Avatar
lowered mine wit coil over sleeves cost 130 installed i mself
Old Oct 18, 2007 | 03:13 PM
Mr_Meaty's Avatar
Coil Over sleaves? The ones from ground controll?
I was considering these. How do they feel and what shocks are you on? Any pics?
Old Oct 18, 2007 | 11:32 PM
sciLon's Avatar
il try n post pics by the end of today......its not ground control its tsudo im running with their springs n sleeves. as for the ride its handles alright but the rides stiff. no finger space in the front n bout 2 n a half in da back. it looks ok. im not sure if this link works but if it doesnt just go look for iceman3366 at the scionrg forum garage
http://www.teamscionrg.com/forum/gar...&image_id=2834
Old Oct 19, 2007 | 02:46 AM
Mr_Meaty's Avatar
Wait, these are adjustable, right? Why would you purposefully have it raked like that...so much higher in the back then in the front?
Old Oct 19, 2007 | 04:36 AM
HyPnOtIk's Avatar
No you wont need a camber kit . The camber is correctable by just an alignment after you let your springs settle for about 3 weeks .
It also depends what size rims you are looking at . if you want rims that are 18x8 then you want to go with H techs or TRD . If you are fine with 18x7.5 then you can go with s techs . an 18x8 wheel will rub like crazy with S Techs .
