How to chop your automatic shifter in half! DIY
Old Oct 28, 2007 | 01:01 AM
xbox523's Avatar
Default How to chop your automatic shifter in half! DIY
What do you think of my automatic shifter?
Got it from Pepboys for like $25. heres how I did it.
Take off huge auto shifter with two phillips head screws and I just kept the overdrive buttom on and tucked it back in center consule. Next I took a fine saw and went around the metal post BUT be careful not to cut the plastic piece. You need this for shifter release.
Here is how much I took it down.
The inside of the shaft of the new shifter to fit over metal rod. Tighten it firmly and you have a short modified shifter that doesnt hit the side of your leg!
What do you guys think?
Old Oct 28, 2007 | 01:06 AM
ROBs-xB's Avatar
thats cool!
seems to add more space to the front
Old Oct 28, 2007 | 01:11 AM
xbox523's Avatar
I'm 6' 4" I need all the room I can get!
Old Oct 28, 2007 | 01:41 AM
xbox523's Avatar
I still see a ton of stock 4x4 shifters out there at car shows!
Old Oct 28, 2007 | 02:12 AM
daneisthegreatest's Avatar
thats pretty cool...
Old Oct 28, 2007 | 03:08 AM
813_toaster's Avatar
KAD
Looks good, I want to do something like this but with a flight simulator joystick, do you think I would still cut it down that far?
Old Oct 28, 2007 | 07:03 AM
burstaneurysm's Avatar
Not too bad.
Old Oct 28, 2007 | 12:01 PM
xbox523's Avatar
813 toaster just keep cutting lower and lower to you reach where you want. This mod is a must do. The bulky t handle shifter is the worse. Just becareful not to cut the plastic rod, only cut the metal. Then leave a tip of plastic.
Old Oct 28, 2007 | 05:42 PM
bB2NER's Avatar
Music City Scions
That looks cool. For me tho with my center console, I wouldn't be able to use the shifter then.
How do you use the o/d button now?
Old Oct 28, 2007 | 06:29 PM
Sid_xBicious's Avatar
Default Re: How to chop your automatic shifter in half! DIY
so after you take off the 2 screws, just pull the head off? is it tight? coz I tried and its a bit tight, I don't want to break or pull any wires?
please enlighten me.
thanks,
sid
Old Oct 29, 2007 | 12:32 AM
xbox523's Avatar
Don't be afraid, it is a little tight but will come off. As far as the od buttom, I live in florida and hell I don't even know when you need it! I just left it on and put it under the consul tucked away.
Old Oct 29, 2007 | 04:31 PM
bB2NER's Avatar
Music City Scions
I use my O/D button all the time. Mostly when climbing long hills with the cruise on so it doesn't keep shifting up and down.
Old Oct 30, 2007 | 12:34 AM
xbox523's Avatar
I just leave it on all the time. There is no hills in FL!
Old Oct 30, 2007 | 12:55 AM
SOxB's Avatar
this gives you better access to the drink holders...I was looking at cutting the bottoms out to give better support for the cups...mine always wants to tip over at every turn or lane change...
Old Oct 30, 2007 | 01:02 AM
bB2NER's Avatar
Music City Scions
We use 52 oz. Bubba Kegs. They fit snugly between the seats on top of the e brake handle.
Old Oct 30, 2007 | 07:53 AM
snowromance's Avatar
good idea. cool mod.
Old Oct 30, 2007 | 11:04 PM
xbox523's Avatar
thank you
xA_2005_runabout
Jun 1, 2015 04:49 PM
SpaceCaptain
May 11, 2015 06:24 PM
Scionxa180
Scion xA Aero & Exterior
Jan 8, 2015 08:33 PM
disaster06
Dec 4, 2014 07:05 PM
TravisXA
Aug 5, 2004 10:10 PM
