Redline Ebrake boot install.
Old Nov 2, 2007 | 05:21 AM
icemanscion's Avatar
Default Redline Ebrake boot install.
Ok so i can't figure out how to install the damn thing, i have read the install guide from redline and it doesnt help me much. Anyone can gimme a picture diy? or some better worded tips? and what should i use to keep it in place?
Old Nov 2, 2007 | 08:05 PM
toeveryhour's Avatar
I'm gonna install mine this weekend, i'm probably going to hot glue it or soemthing.
Old Nov 2, 2007 | 08:45 PM
PlayinWithFire's Avatar
people use tape... electrical tape is pretty sticky...
Old Nov 2, 2007 | 08:56 PM
TinCan's Avatar
Well bubble gum works good too!!!
iI you are going to use ele. tape, buy 3m tape its called "Super33" its by far the best ele tape on the market.
Old Nov 2, 2007 | 09:11 PM
you might have to adjust the number of clicks on the ebrake too (if you use it) mainly because the boot restricts it from going all the way up.
Old Nov 3, 2007 | 01:54 AM
2_tC's Avatar
Duct tape holds up better, electrical tape will start to lose it's stickyness in the heat.
Old Nov 3, 2007 | 04:14 PM
TinCan's Avatar
super 33 will not lose its sticky, but the duct tape will work too
Old Nov 7, 2007 | 08:06 PM
still need help!! i tried to tape it and it gets clumpy / ugly and doesn't sit right, can anyone please help me out?
Old Nov 7, 2007 | 08:09 PM
lil_will's Avatar
ScionERA
Thats the problem I ran into.
Old Nov 7, 2007 | 08:21 PM
smilezdc's Avatar
x2..
Old Nov 7, 2007 | 08:25 PM
GQQSE13's Avatar
good info, was about to order
Old Nov 7, 2007 | 11:03 PM
BZinn1's Avatar
What I had to do was remove the rubber flange that is on the console .......when you do this you then need to take an exacto knife and cut off the tabs hat held on the rubber flange.
then take some sandpaper to the bottom side of the console where the boot is going to mount.....and rough it up a bit then take some alcohol to clean the surface.....
A good epoxy for plastic will work great......I got a tube for like $3 from home depot called Handymans epoxy and it works on plastic,leather,wood,metal,etc.....
apply it to the console around the underside of the opening where you sanded and press the boot into place.the bot has cuts on the seams that almost fit perfectly to the new opening.....work with it a bit before doing the glue.
My brake goes all the way up no problem.......and it fits perfectly....at first the opening over the handle itself was a little tight but it has stretched out enough to flow freely now.......been 90 days now and it is still in place with no problems.
Tak16
Jul 7, 2015 05:45 PM
Brimhall_29
Jun 20, 2015 03:40 AM
kleecker
May 2, 2015 01:22 PM
phillytc
Mar 25, 2005 06:30 AM
jackmott
34
Apr 12, 2004 07:53 AM
