camber adjusting
Old Nov 6, 2007 | 06:48 PM
nvthetc's Avatar
Default camber adjusting
Hey I was wondering if any one had any sugestion on what to do about my rear tires wearing quicker on the inside of the tires. This is only happening in the rear. I have put the TRD springs on my car, which is not a sugnificant drop for after market springs. I never did get my car aligned. Cause i no i have a negative camber. Therefore, do you think that if I get my car aligned where they fix my camber that will solve the problem or has anyone else out there had a similar problem? Thanks.
Old Nov 6, 2007 | 07:00 PM
draxcaliber's Avatar
need to get your car aligned. that and ofcourse, rotate your tires soon.
Old Nov 6, 2007 | 07:07 PM
nvthetc's Avatar
K thanks man. I have rotated my tires. Everyone even says they can see my tires tilted in when driving behind me. So do you think just getting it aligned with out a camber kit will work?
Old Nov 6, 2007 | 07:13 PM
you really don't need camber until you go over a 2 inch drop.
i have the trd drop, waited a week, got it aligned, haven't had any unusual tire wear at all. and the dealers verified that my alignment was out of spec before the alignment was done. and no, didn't need any sort of camber kit.
Old Nov 6, 2007 | 07:18 PM
Varsis's Avatar
um, might i suggest new tires and a proper alignment now since ya didnt' do it when you were supposed to?
Old Nov 6, 2007 | 07:28 PM
not a bad idea considering winter is coming up, and up here in frostburg, we just had our first snow flurry today...
Old Nov 6, 2007 | 08:51 PM
KINGxOFxSKA's Avatar
Unique Scionikz
http://www.promotiontuning.com/Merch...spensionCamber
Old Nov 6, 2007 | 08:59 PM
lenix38's Avatar
Definitely get the alignment ASAP. I got the TRD springs, and it didn't require anything extra. Also rotate your tires if the wear is pretty bad on the rear.
SeanstC's Avatar
drax you saw a flurry? ah man... wtf..
Old Nov 6, 2007 | 09:07 PM
well, i do go to school in a town called frostburg, which is by no means a misnomer. i go home everyweekend to montgomery county and there is a fairly consistant difference of about 10 degree's between the the two. granted there is also a major difference in the elevation between frostburg and moco.
but yeah, monday mornings when i roll up to campus, the frost on the cars is so thick it looks like it did snow, and sometimes when i drive home with snow on my car from frostburg to moco, everybody looks at me like "where did he just come from and why is there snow on his car?"
Old Nov 6, 2007 | 11:34 PM
adg016's Avatar
Toe out can be killing your tires too, as can a blown shock.
Old Nov 8, 2007 | 06:17 PM
chicotunner07's Avatar
about how much does an alignment at a toyota dealership normally cost? will they do it on a car lowere on Htech springs?
Old Nov 8, 2007 | 06:26 PM
bencott's Avatar
yeah, i have htechs with no camber kit. i took it in for an alignment a couple weeks after the install. that was about 20k miles ago, and there's no uneven wear on my tires. cost depends on where you go, but it should be $50-$80.
Old Nov 8, 2007 | 09:10 PM
alignment at my toyota dealership is $99.00
Old Nov 12, 2007 | 08:37 PM
shoopajae's Avatar
i know firestone or somewhere that if you pay 150 upfront, you get unlimited alignment for a whole year.
but im not sure if they'll mess with anything that deals with aftermarket parts....
Old Nov 12, 2007 | 08:57 PM
BlueTC06's Avatar
I installed some H.Techs about a month ago and when I did the alignment on my rear I adjusted it as far as it goes and I still have a neg camber on the rear...the problem is that Toyota does this to make money because on the front you have to buy a new bolt but on the rear you have to grind out the bolt hole to make it even again...its all about money
SloTC1
Aug 16, 2018 02:45 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
domincnTC
Aug 4, 2015 01:47 PM
Subaru86
Jul 31, 2015 04:33 AM
Subaru86
Jul 31, 2015 04:00 AM
