most beneficial (performance) suspension mods ~$500
Old Nov 8, 2007 | 12:32 AM
trix5032's Avatar
Default most beneficial (performance) suspension mods ~$500
What is it? I'm thinking swaybars, but i was just looking for others opinions.
I'm wanting to spend about 500 on my suspension and i don't care about ride height. I'm also trying to do this without getting an alignment, but that isn't a must
Old Nov 8, 2007 | 12:42 AM
draxcaliber's Avatar
hotchkis front and rear anti-sway bars. they will make a huge difference in the cars handling.
Old Nov 8, 2007 | 12:44 AM
GammaTNT's Avatar
your best option is to get Hotchkis Sway Bar.
any mod with springs or shock will need realignment.
Old Nov 8, 2007 | 01:32 AM
2fast4you's Avatar
Team ScionTific
The most beneficial (performance) suspension mods ~$500?
Tires. Sway bar, spring, and damper upgrades mean nothing without grip.
Old Nov 8, 2007 | 01:38 AM
matt's Avatar
+1 to that. i got the hotchkis f/r sways with TRD springs for like 450 @ mcgeorgeparts.
worth every penny. improves handling 10-fold.
Old Nov 8, 2007 | 01:49 AM
wel, tires are a great suspension upgrade, but they are more of a consumable wear and tear suspension upgrade. not something that you can enjoy for a tens of thousands of miles like sway bars.
Old Nov 8, 2007 | 03:50 PM
HaYnSktC's Avatar
go with the hotchkis tvs
it has the springs and both sways =)
Old Nov 8, 2007 | 05:23 PM
Keeshwah's Avatar
ya, and a good excuse to upgrade when your tires get bald from carving corners anyway.
Old Nov 8, 2007 | 05:30 PM
trix5032's Avatar
i wish i could find these used for about $300
Old Nov 8, 2007 | 06:10 PM
MPG-Motoring's Avatar
A rear sway bar and a good set of tires will make a significant difference. Once you start going with lowering springs and coilovers you'll need to adjust camber and get a proper alignment, this will make your car handle very well but it will cost a lot more then $500.
Old Nov 8, 2007 | 08:46 PM
trix5032's Avatar
im not wanting to track this car or anything. just make it handle a little better for that fun to drive feeling. new tires will come when the stockers are burned through but im reaally not in a hurry to do that.
Old Nov 9, 2007 | 04:02 AM
tC9o9's Avatar
TIRES
You can invest 5000000 dollar into your suspenion, but if your tires cant hook up, then its no point.
Old Nov 9, 2007 | 03:40 PM
trix5032's Avatar
Originally Posted by tC9o9
TIRES
i realize this. tires are a wear item though. they will be replaced when the stockers wear out, as i stated before. im looking for non wear item investments.
Old Nov 9, 2007 | 05:05 PM
Keeshwah's Avatar
sways it is. get em, u wont regret it. it was the first thing i did to my car and i couldnt imagine it without it.
Old Nov 12, 2007 | 04:00 AM
RnB180's Avatar
sway and springs.
Old Nov 12, 2007 | 05:31 AM
Beantowntc's Avatar
Sways
Old Nov 12, 2007 | 02:24 PM
sexybluetc's Avatar
Which is a better option:
1 Hotchkis Sport Sway Bar + RED TRD lowering springs
or
1 Hotchkis Stage 1 TVS System
And if it is the TVS system what type of drop does it have?
Old Nov 12, 2007 | 03:37 PM
or
either one will do fine, it is more of a preference in how low do you want to go. 1.25 inches, or 1.7 inches.
also, the trd springs color doesn't matter, they made them in white firs,t and now they make them in red. no difference in drop or performance.
me personally, i choose the trd springs because i don't want to worry about scraping on steep approach/departure driveways, and because they came in a good package deal from www.trdsparks.com.
Old Nov 12, 2007 | 04:12 PM
sexybluetc's Avatar
I'd like to stay around 1.25" drop so the TRD springs look the way to go.
Now on to the sway bars. It seems TRD only has a rear sway bar while Hotchkis has both front and rear. I know usually the rear sway bar is the one that you want to upgrade at a minimum, but am just getting started with the tC and would like more opinions on that.
Old Nov 12, 2007 | 05:38 PM
Bozuzu's Avatar
it doesn't matter. get tires. there's nothing better. once you spend $1000.00 on tires you will LOVE that little car, even with the stock suspension. BUT, since you said you only have $500, get the rear AND FRONT sway bar from hotchkis, lots of fun, and if you still have change, get the rear strut bar from ingalls. my favorite.
[/img]
