takeoff
Old Nov 9, 2007 | 10:16 PM
e246's Avatar
Default takeoff
alright i was talkin about cars to friends at work today and they said you should be able to take off in a stick without revving it a little. they said its bad on the transmission and stuff. but what i do when just normal driving is let clutch half way then rev it to like 800-1000 rpm and slowly let the clutch go, is this wrong?
Old Nov 9, 2007 | 10:34 PM
engifineer's Avatar
If you take off without giving it throttle, it will stall the engine. You should give it a little gas, let out the clutch and increase throttle evenly as you let out, basically keeping the engine speed at the same point the whole time. And you want to learn to do it fairly quickly, but not so quick it is jerky, so you dont slip the clutch excessively.
Old Nov 10, 2007 | 03:05 AM
nforce4's Avatar
Yeah, you can start off without using any gas at all. It takes some time to master it, but once down it works fine, and also increases the life of the clutch. Giving a little gas is normal but does wear on the clutch, or what we call "Riding the clutch". I have owned 3 stick cars, and I never use the gas to roll out of first gear. Never had any powertrain issues either, but that may just be me.
Old Nov 10, 2007 | 03:56 PM
engifineer's Avatar
Giving it a slight bit of throttle makes for a better take off and does not hurt your clutch. That is how a manual is designed to be driven. Letting off more slowly on the clutch to take off with no gas just slips the clutch even more.
Old Nov 10, 2007 | 04:10 PM
aen's Avatar
aen
and here i thought i've been driving stick wrong my whole life
i was taught to let go of clutch, hit gas.
i never drove like that, instead i gas a little. let go of clutch.
the things we are taught huh.
Old Nov 10, 2007 | 04:24 PM
engifineer's Avatar
It is all timing really. You dont need to have i revved before you start letting off... you do it as you let off in one smooth motion.
Old Nov 10, 2007 | 04:28 PM
aen's Avatar
aen
^^ exactly, it took me a while to figure that out though.
aksc
Nov 10, 2011 09:56 PM
sciontcmm
Scion xD Wheel & Tire
Apr 14, 2009 01:24 AM
Davestoaster
Apr 12, 2009 08:19 PM
eddy524
16
Mar 20, 2009 06:17 AM
dgenem
30
Apr 29, 2008 02:14 PM
