alignment settings for autoX or track days
Old Nov 19, 2007 | 07:21 AM
HondaCRX's Avatar
Default alignment settings for autoX or track days
Anyone have any alignment settings they've played with for autoX or track days?
ie. toe or camber?
Also, since I'm a new tc owner, what CAN be adjusted from factory?
Caster?
Camber?
Toe (i know front can, but rear?)?
Old Nov 19, 2007 | 04:21 PM
Scion_South's Avatar
Default Re: alignment settings for autoX or track days
ie. toe or camber?
Caster?
Camber?
A stock tC has a lot of adjustability.
You shoudl be able to get -1.5 to -2.0 camber using factory crash bolts. Toe is adjustable from the factory front and rear. Caster has no real adjustment using factory equipment.
For autocrossing I run about -2 degrees camber up front -.6 in the rear, about 1/8 out for front and rear toe.
If you don't have to worry about stock class rules then I would say the sky/credit card is the limit on adjustability.
Old Nov 19, 2007 | 06:05 PM
HondaCRX's Avatar
wait, you're running 1/8" out front and rear? hmm...
thanks for the response... helps me figure where i can start tinkering around with.
Old Nov 19, 2007 | 06:34 PM
I think it's an 1/8 in the rear. I might not be that much I've changed it a few times over the season. It is just enough to be a little twitchy under hard braking. It turns in pretty good with good mid-corner rotation.
I've got a copy of my alignment specs out in my car I'm sure I can find some time today to post them up.
Old Nov 20, 2007 | 03:21 AM
CSOCSO's Avatar
stupid question: how they set up the alligment? they bending something or the stock camber kit is something like this:
is it easy to loose the alligment fast ( if i drive over a bumper or rails really fast?)
Old Nov 20, 2007 | 12:48 PM
It depends on your goals the eccentric bolt that you have pictured will allow you to get more camber than the stock "crash bolts", but they are not legal to use in the SCCA Stock classes.
When I tried the eccentric bolts I was able to run -2.5 camber, with the factory "crash bolts" I can get about -2 on the right front and about -1.5 on the left front.
If you are not concerned about a particular class to race in you can use what ever you want.
So far I haven't had much problem with the alignment holding using either set of bolts.
Old Nov 20, 2007 | 04:51 PM
CSOCSO's Avatar
no-no-nooo!
its not for that.. im sorry... there would be no bumps-humps or rails on a track :D:D
i was talking about the street. every day driving.....
i dont really know how the alligment things work... my friend said stock cars have no camber kits like that... they have something what they bend or something like that.. and i was like: what??? no wonder you alligment goes bye bye really fast. it means i could go to a shop every weekend to get my alligment fixed..
but i just found a picture about that eccentric bolts and i see thats almost the same thing like those ingalls camber kits......
so there is no bending stuff and things like that.
every car has this crash bolts thing or just my friend is a stupid?
NonStopTuning
Jun 29, 2015 07:42 PM
ninja_steph
Feb 5, 2015 02:50 AM
eatcrispycreme2
Jan 30, 2015 03:42 AM
JDMxB
13
Dec 23, 2003 04:23 AM
Besk_one
Oct 16, 2003 07:45 PM
