installing a new head unit in 08, can you ratain the sub?
Old Nov 20, 2007 | 09:30 PM
unxpectederror's Avatar
Default installing a new head unit in 08, can you ratain the sub?
hey whats up
i wanted install a alpine head unit i have sitting around but i wanted to know if i could retain the factory sub? if i can how do i go about doing so?
thanks
Old Nov 21, 2007 | 10:33 AM
fast5's Avatar
Its possible but might be more work than its worth. You would have to splice all wiring from factory amplifier by the sub and then slice the sub wiring.
Old Nov 21, 2007 | 12:12 PM
couldn't i just splice it where the sub amp meets the head unit and hook them wires up to a set of rca's and run the sub amp out of the units rca out?
or is the sub amp not even connected to the head unit and is crossed over from the rear speakers?
any info would be great
thanks
Old Nov 21, 2007 | 03:56 PM
ADRdesignCo's Avatar
from what ive seen with the factory sub (or at least the vst), they usually take speaker level in, so youd have to tap into the rear speaker signal. depending which head unit you choose you might be able to retain the sub control at the headunit. ive done this with the VSE bazooka sub and the avic d3. at the cost of losing his rear speakers he was able to retain sub control at the headunit and the front speakers.
Old Nov 21, 2007 | 04:57 PM
WAlterEgo's Avatar
well the sub will work if u hook it up as is, but u ont have much control, if any. they're hooked up to the rear speakers somehow, i know that much
Old Nov 21, 2007 | 05:06 PM
its through a special plug and play harness behind the deck. when i played with the vse subwoofer it was actually tapped off the front speakers.. kinda odd but it was.
Old Nov 21, 2007 | 06:20 PM
ichibansf's Avatar
Ditch it and get the eD hidden sub. The factory sub is a nice line item, but isn't really worth keeping.
wiltonhall
Jun 23, 2025 10:09 PM
clickclickw00t
Feb 18, 2015 08:57 PM
XB06
Feb 16, 2015 06:03 PM
NewBox06
Feb 3, 2015 04:02 AM
billzor
Scion tC 2G ICE & Interior
Jan 17, 2015 12:38 PM
