"Engine Start" button
Old Nov 23, 2007 | 07:34 PM
Vlad1024's Avatar
Default "Engine Start" button
I would like to install one but an a total electronics n00b. can someone tell me what i need and how to install it. i want to still be able to start with the key and have the button light up with my headlights.
I tried searching but found very little on what's actualy needed and how to wire it.
Thanks
Old Nov 23, 2007 | 07:37 PM
hawgs74's Avatar
If u buy a button it will come with wiring instructions. But basically u tap into the ignition wires (2) and install a relay onto each.
Old Nov 23, 2007 | 07:45 PM
Vlad1024's Avatar
What if i want to use the s2000 button?
Old Nov 23, 2007 | 07:50 PM
hawgs74's Avatar
Thats the one I have
I used this because it came with harness and relays but If ur tech saavy u can make your own
http://cgi.ebay.com/GENUINE-S2000-ST...QQcmdZViewItem
Old Nov 23, 2007 | 08:04 PM
RodC's Avatar
How does the button work in conjunction with the key? I know I could search, but I'm too lazy, and I'm only a little bit intruiged. Do you need to have the key in the ignition to use the start button?
Old Nov 23, 2007 | 08:23 PM
hawgs74's Avatar
U can wire it however u want. Delete the key or not. For mine the key has to be in the ignition but thats so someone cant just break my window and start my car.
Old Nov 23, 2007 | 11:20 PM
Vlad1024's Avatar
can you post or pm me the instructions that came with it?
Old Nov 24, 2007 | 04:50 AM
Zebman's Avatar
You have to use the key still.
Bypassing the key will be somewhat complicated, with the immobilizer system and hard access to the ignition.
Old Nov 24, 2007 | 03:30 PM
Vlad1024's Avatar
can sombody tell me how to wire it. Diagrms would be appreciated. Thanks
Old Nov 24, 2007 | 03:37 PM
hawgs74's Avatar
Contact the guy that sells them since he's probably the only one who has diagrams just laying around.
Old Nov 25, 2007 | 11:33 PM
Vlad1024's Avatar
has anyone who has this mod accounted for the fact that acc is turned off when the key is turned to start.
Old Nov 25, 2007 | 11:46 PM
a_german_named_hans's Avatar
Just curious. Does the key have to be in the ignition for the immobilizer to work. Or say you have a back up key w/o a chip and you have the legit key in your pocket. Would that be enough or still trip the immobilizer?
Old Nov 26, 2007 | 12:09 AM
cwayne's Avatar
Ghetto:
http://youtube.com/watch?v=ah9fD3oq9uE
lsjimenez
Apr 3, 2015 01:32 PM
randompacking
Jan 28, 2015 11:43 AM
DerekMarq
Jan 27, 2015 02:38 PM
Kiwibox
Dec 15, 2014 09:46 PM
jdtjunior
Jan 16, 2004 06:20 PM
