would it be safe to change the tire profile to a higher one?
you will have to change your wheel to a smaller one so you can run a bigger rubber or else you will mess up your ODO and speedometer.. As long as the overall wheel diameter is within or very close to specs then you should be fine
Originally Posted by cladams0802
need some feed back
You can get away with running a tire that is no higher than 2% or -%2 of the the actual size tire. Anything bigger than that will cause some problems.
Check this website out to see what % the tire you want to change to is compared to stock
http://www.powerdog.com/tiresize.cgi
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
Jan 18, 2016 08:41 PM
mrsocks
Jan 20, 2015 01:29 PM
pscionicpowers
22
May 18, 2006 01:40 PM
