PowerSlot Plus rear rotor help please.
Old Dec 6, 2007 | 10:09 PM
Imperial's Avatar
Default PowerSlot Plus rear rotor help please.
For any of you who may be using the same rear setup (e.g. PowerSlot Plus rear rotors) I would like to ask for your help. I've noticed that a thin area on the thicker slotted surface of the rotor after the heat dam is not making any contact with the brake pads thus not getting any wear at all, is this normal for this brake setup? You can clearly see what I'm talking about from the picture below. I appreciate any feedback on this matter.
Old Dec 6, 2007 | 10:17 PM
draxcaliber's Avatar
so you put bigger rotors on, and your concerned that the pad isn't touching the whole thing?
you put on bigger rotors, but your pad is the same size. so as long as the pad is touching 100% surface contact with the rotor, it shouldn't be a problem.
Old Dec 6, 2007 | 10:45 PM
Imperial's Avatar
You have completely misunderstood me; I’m not at all concerned of my pads “touching the whole thing.” What I am concerned of is if it were not making contact up to the point where it is supposed to. If a rotor was designed to make contact with the brake pads up to a certain point, which this appears to be, I would expect it to be no less than thus. The contact area on these rotors have been raised and slotted, I’m worried that this may cause uneven wear of the rotors and pads down the road.
Old Nov 17, 2008 | 03:53 PM
StreetStarsTc's Avatar
or it could mean that your rotors are warped thus causing uneven wear on the pads and rotors
Old Nov 25, 2008 | 12:49 AM
mattieg's Avatar
dude i cant see jack in the picture. if you want us to figure it out take a picture of the rotor... not the car all blinged up.
Old Nov 25, 2008 | 01:43 AM
davedavetC's Avatar
lol guy, you posted a pic of youre car (idk if its yours but im guessing it is) that shows nothing of your rear brakes.
Old Nov 25, 2008 | 02:05 AM
mattieg's Avatar
thank you dave! i think this is just a thread of "hey look what i got"
Old Nov 25, 2008 | 05:58 AM
HKSpeed's Avatar
I used to have the Powerslot Plus rear kit and I understand your problem. You'll just have to check the pads occasionally and break (grind/cut/dremel/etc) off the unused portion of the pads.
for those who dont know what the problem is you can read about it below. Toyota Matrix owners had the same problem.
http://matrixowners.com/?showtopic=53392
Old Dec 6, 2008 | 04:11 AM
ttegtfour's Avatar
the other problem you will have is the pad make alot of noise from the unuse portion of the rotor !!!! I have same issues going to buy real bkk
ivanhoe
15
Sep 23, 2016 06:20 PM
rarias32
Scion tC 1G ICE & Interior
Apr 24, 2015 01:11 AM
sciontcdriver1
Feb 3, 2015 05:09 PM
Slopoke21m
54
Apr 23, 2007 12:25 AM
avus
Dec 3, 2003 12:46 AM
