Recomended 50k miles service
Old Dec 16, 2007 | 04:38 PM
IndigoXb's Avatar
Default Recomended 50k miles service
Well I'm home for the holidays and about to roll over to 50,000 miles on my 05 xb. I was thinking if there are any particular things that you recommend maintance wise for the car with 50k? I'm think that I should probably get the a new fuel filter, and the coolant change? Obviously I change the oil every 4000k its mobil 1 synthetic, but is there anything else I should look into?? Thank you.
Old Dec 16, 2007 | 04:47 PM
Jan06xB's Avatar
Don't do the coolent - it is supposed to be special Toyota LifeTime stuff and does not need changing but check the level in the overflow bottle. Power steering fluid change would be a good idea if it is very dark. Have you checked the suspension nuts and bolts? Sway bar bushing and shock mounts?
Old Dec 16, 2007 | 05:01 PM
tanakasan's Avatar
Check that cabin air filter! Mine gets bad in 5K miles so I change it with every oil/filter service.
Old Dec 16, 2007 | 05:25 PM
IndigoXb's Avatar
Thanks for the replies guys, I checked the suspension bolts, when I put my sway bar on I checked all the suspension nuts and bolts. I have never changed the power steering fluid so I will probably do that. Anything else??
Old Dec 16, 2007 | 07:15 PM
Jan06xB's Avatar
Check your spark plugs, brakes pads and fluid level, CV joint boots for rips and leaks, belts, battery cable connections and blue eye, maybe check or change the tranny gear oil if you haven't already. Spare tire for 60psi air pressure and under carriage for rust and bare metal spots including any exposed brake and fuel lines for corrosion. Exhaust pipes and Cat for rust and holes. Lubricate door hinges and locks. Tire wear for alignment issues.
Old Dec 16, 2007 | 11:49 PM
xbizzle562's Avatar
You might also want to check too see if your AC needs to be recharged
Old Dec 17, 2007 | 12:13 AM
Romanova's Avatar
Check the recommened maintenance guide... it tells you what to do and when.
Old Dec 17, 2007 | 05:30 AM
snowromance's Avatar
+1 to the maintenance guide!
Old Dec 17, 2007 | 11:50 PM
IndigoXb's Avatar
does anyone know if there is a place online that I can find the maintance guide? I can't find mine. Thanks.
Old Dec 18, 2007 | 12:37 AM
tanakasan's Avatar
I *believe* its available on the Scion website.
I know its available on the web...Google "scion maintenance" and they will pop up from dealerships.
Its easy! Really!
Old Dec 18, 2007 | 02:24 AM
layzieb36's Avatar
Its easy! Really!
Old Dec 18, 2007 | 02:31 AM
Jan06xB's Avatar
http://www.oakbrookscion.com/Service-Pricing.aspx
Here is a good list with optional stuff at the various mileage intervals and pricing to do the work.
Dmmcclair
Aug 13, 2015 07:14 PM
kleecker
Mar 17, 2015 12:15 PM
toyotaisme
Jan 10, 2015 10:24 PM
vho
15
Feb 9, 2004 01:58 AM
BlueBox
22
Nov 7, 2003 08:18 PM
