supercharger noises?
I have a 2005 tc and i have just recently purchased from a dealership all the supercharger, pulley, exhaust, and forge bpv has only been on for about 5k miles give or take. When i went and test drove the car at idle i heard a ticking i just from the bpv and the supercharger itself rattled until you gave it some gas is that normal? Well last night as i was on the way home from a friends house i started hearing wierd noises. It almost sounded like a clutch fan but it was in the s/c its like you cant hear the whistling sound anymore all you hear is this humming sound does anyones know what this could be
yeah it wines but at idle it just started doing this last night! im not sure what that would be it a clutch fan when you rev up it revs with it you hear no more whistling from s/c you just hear that it sounds awful
do not drive your car! From the sound of it, it is most likely the bearings that have gone bad...an all too common problem with the supercharger. If you live in so cal, i have a solution on how to solve it if the person is willing and available...but if not, you should check around your local tuner shops because the dealers do not know how to replace this and will tell you that you need to get a new one. Now, if your warranty is still intact, they should replace it for free...hope you don't have any other mods done to the supercharger or engine that didn't come with the supercharger kit (exhaust excluded) because then the warranty is no good! either way, get it checked immediately as i too have had this problem once
oh, and so does the pulley changing, you have pretty much no warranty unless you can get it back sto stock.
now really, you've had the supercharger for 5 thousand miles, you shoulda kinda gotten used to what was normal and what isn't over that time.
I might be having the same thing going on. S/C'ed for 5K miles... I can hear it mostly in 3/4/5 gear. When I give it a little more gas than coasting, it makes a whirring sound... hard to explain. Almost the same sound as when the ground is wet and spraying your fenders, but I'm pretty sure it is from the supercharger. I'm not sure if I should be paranoid or not. Is this what is going on with yours? I'm pretty sure that the sound has just developed in the last 300 miles.
^ I have a smilar noise, it only happens when its about 35 degrees out and I have made more than 10psi of boost. Check your oil. I got mine changed and the sound went away after that. Now if only I could get this NEW belt to stop squeaking I would be set.....
ok greenbox from this forum told me to get a new bearing from "AUTOZONE PRT # IS90099-10091 THOSE ARE FOR THE BEARINGS FOR THE PULLEY AND THE ONES INSIDE THE CHARGER AREPTR01-21054"
went there and they cant seem to locate it. i was just wondering if anyone else out there that can locate the part. thanks for all the help.
