dash noise near radio
Old Nov 3, 2004 | 03:35 AM
daggerSLADE's Avatar
Default dash noise near radio
hey i know that many people have experienced the dash noise near the radio when ya go over bumps with the TC .. what has been done to fix this? also, can i complain to the dealer about it after i had an aftermarket radio installed? its really aggrevating me especially after the long trip i just took ... have to turn the radio up to not hear it ... seems like the squeaks and creaks are common in this car
please respond :?
Old Nov 3, 2004 | 04:09 AM
unlimited77's Avatar
i didnt read your post but i think its the alumin. temp **** try holding it next ime...i need to go get mine checked cause i know its that on my car when i drive it rattles and its annoying as hell.
Old Nov 3, 2004 | 04:17 AM
thanks for the response .. i dont know about the temp *** thing .. the sound seems to be coming from the air vent area ... its weird .. thanks for the tip tho .. i will try that
Old Nov 3, 2004 | 04:28 AM
chipmOnk's Avatar
you mean the squeaking sound when you're going like 80 on the freeway?
Old Nov 3, 2004 | 05:03 AM
zizi's Avatar
I had squeaking around the radio during the 2nd and 3rd months. The first month and the last month, 4th have been squeak free. That squeaking sound is annoying though. My Scion TC fixed itself and no more squeaking.
Old Nov 3, 2004 | 05:07 AM
Kev_the_rev's Avatar
i got a rattling near my radio too... I'm guesing that its some loose screw or something in there.. its weird. I just give it a quick hit and it goes away for a lil bit..
I'm taking my car in to have it looked at this weekend
Old Nov 3, 2004 | 07:12 AM
hahaitzskippy's Avatar
ya i get the squeak too. itsfro m that dam door. i havent found a way to fix it...
more lik i dindt care anymore
Old Nov 3, 2004 | 09:08 AM
mo2's Avatar
mo2
its from one of the springs (if you can call it that more like a bent peice of copper) that helps open and close your radio door. just pull it off and deal with a door thats ackward to open and close. or you can try some dynamat on it or that rubbized spray
just a thought
Old Nov 3, 2004 | 12:19 PM
fearturtle44's Avatar
just a thought
How do you take the door off? I tried slanting the door some as I pulled on it but no luck. And I didn't want to break it. I was hoping to just shoot some kind of lube but didn't know where the springs started/ended.
Kevin
Old Nov 3, 2004 | 12:43 PM
lebshiff21's Avatar
yeah it's defnintely the stereo door. **edit** annoying squeak too, sounds like a mouse. I'd love to know how to get that door off.
**Edit - Language**
Old Nov 3, 2004 | 03:51 PM
Streeter's Avatar
My radio squeeks too - if you hold the lower right of the radio with your thumb it'll stop. Nothing that a new stereo wouldn't fix. ;)
Old Nov 4, 2004 | 12:33 AM
engifineer's Avatar
It is definintely the stereo cover door... you can close it and it helps a lot. I havent had time to look into fixing it as of yet, so I am not sure if it is the pivots (plastic on plastic) or the springs...
Old Nov 4, 2004 | 01:50 AM
blitzcat's Avatar
My door squeaks also. It used to be only on the highway, but now its almost constant (after i put on trd springs). Not that I have my tC anymore. I have a ____ty corolla while it gets repaired/repainted.
I'm afraid to ask my dealer to fix the squeak because last time they 'fixed'something ( the alignment) they tore a large piece off the front air dam. I can't afford to have the mechanics learn on my car anymore. Someone post a solution....
Old Nov 4, 2004 | 02:46 AM
nycazn79's Avatar
I have the squeaking radio door too. It only started after I replaced the stock HU with an aftermarket unit. It usually gets loud on bumpy roads or highways. I noticed if you push the cover down in certain places, it will stop the squeak.
I'll experiment by purchasing some foam tape and place it in certain spots behind the cover to hopefully stop the noise.
Old Nov 4, 2004 | 04:11 PM
tCholleration's Avatar
i dont know if its just me. maybe.... but anyways, ever since i got my car, i'va always had trouble opening that stupid door. i have to push on it multiple times just to open it. what the heck?!
Old Nov 7, 2004 | 06:26 PM
ya tat door is retarded sometimes.
sometimes it wunt close until i slam it.
Old Nov 7, 2004 | 11:23 PM
Harman's Avatar
I think I have found the squeaking source. If you pop the center console from the radio, disconnect the harness. THen, flip to the backside and look for this little black pin on the left side and right side. The pins are inserted into a groove that used to support the back side. THerefore, everytime you hit a bump or drive over some rough road, the pin will move against the groove and produce the extremely annoying squaeking. I am pretty sure I have found the source because I basically shake the whole piece and reproduce the squeak consistently.
I used WD-40 to spray on it and the squaeking was totally gone. However, after a week, the lubricant was spreaded too thin and the squaeking begins. I will buy some silicone grease (paste) to lube it and hopefully the sound will go away. If you have squaek, you may want to lube the pins and see if its helps.
Old Nov 25, 2004 | 04:45 PM
im gettin a new radio door installed tomorrow (11/26/04) to see if the noise goes away .. also im gettin the door cuz im havin problems opening the door itself .. so we shall see what happens ...
Old Nov 29, 2004 | 06:17 AM
lyrictenor1's Avatar
Any news on this front?
I recently had an aftermarket HU installed and now have a this squeak which is actually quite loud. I took it back to the shop and they said they couldn't locate the rattle, but glued some parts to see if that would help. Well, it didn't, so I took the dash out myself and tightened a few screws. Worked for a bit but the squeaks came back shortly afterwards. When I get some time this week I'm gonna take it out again and see if can get the HU to stop moving around--when I hold it down it stops squeaking.
Old Dec 3, 2004 | 10:43 PM
daggerslade, any news?
