Lock this thread
Old Dec 20, 2007 | 05:33 AM
tCtCtC's Avatar
Default Lock this thread
Old Dec 20, 2007 | 05:37 AM
CRUZtc8's Avatar
^^ watching...
Cant wait to see the finish product.
Old Dec 20, 2007 | 05:39 AM
tCtCtC's Avatar
Old Dec 20, 2007 | 05:44 AM
xbguy714's Avatar
that sounds sik cant wait to see the final project
Old Dec 20, 2007 | 05:45 AM
Haro287's Avatar
Sounds like a lot of work, just make sure you plan it all out financially, otherwise you'll end up broke.
Old Dec 20, 2007 | 05:46 AM
ADRdesignCo's Avatar
sounds like a plan. good luck!
Old Dec 20, 2007 | 05:47 AM
BuddhasTC's Avatar
don't forget in phase 3 to also get a wideband a/f ratio gauge with an 02 sensor...most important with f/i...another recommendation is an EGT gauge...will also aid in showing you if ur running lean
Old Dec 20, 2007 | 05:48 AM
tCtCtC's Avatar
Old Dec 20, 2007 | 05:53 AM
tCtCtC's Avatar
Old Dec 20, 2007 | 05:56 AM
AcidDrop's Avatar
i think your better off doing pahse 4 before phase 3 cause then you won't have to worry about removing the s/c just to put in the headers unless you feel like struggling for quiet a while just to fit the headers and if you plan on putting an oversized pulley your not gonna be able it remove that easy cause supposely the dealer carries that tool to remove the bolt, but yeah GL on your project.
Old Dec 20, 2007 | 05:57 AM
Dakine's Avatar
Concept in Motion Crew
get this done before january!!!
jaxtcracer's Avatar
you're going to have fun w/ that list of modifications
Old Dec 20, 2007 | 05:59 AM
tCtCtC's Avatar
Old Dec 20, 2007 | 06:00 AM
tCtCtC's Avatar
Old Dec 20, 2007 | 06:15 AM
Aroddalobster's Avatar
1. that sounds like a pretty awesome list of things to accomplish. can't wait to see it in it's final form.
2. another new name?
Old Dec 20, 2007 | 06:22 AM
Ro_Ja's Avatar
Default Re: Phase 1: Has just started.
Originally Posted by iBask
Dropped off the RS1 lip kit to be painted at A&A and have them custom fit my carbon fiber heat shield onto the rear lip :D
I REALLY want to see how that turns out because I have the cf exhaust shield, but I really want a lip kit.
Also, in Phase 4, you list the Injen intake, but it isn't compatible with the supercharger...unless you plan to modify it to fit...
Old Dec 20, 2007 | 06:26 AM
2_much_tc's Avatar
i hope you know that the price from trdsparks for the s/c ends at the end of this month... you should do phase 5, then 4, then phase 3 to do it the right way. but good luck with that...
Old Dec 20, 2007 | 06:27 AM
tCtCtC's Avatar
tCtCtC's Avatar
Old Dec 20, 2007 | 06:28 AM
tCtCtC's Avatar
