any idea
Old Dec 22, 2007 | 07:01 PM
thispecialk's Avatar
Default any idea
anyone have any word when will the s/c for 2008 will go down i dont want to wait forever but i dont want to spend all that money also.
Old Dec 22, 2007 | 07:14 PM
2fast4you's Avatar
Team ScionTific
This is pure speculation, but I'm guessing they will reduce the price once the new Scion coupe model is released in year or two.
Old Dec 22, 2007 | 10:50 PM
well thats ___ 06 s/c went down its only been 1 yr it the same thing wat makes the 07 or 08 any better
Old Dec 23, 2007 | 01:06 AM
gjpjr84's Avatar
the 06 charger wasnt really different then the 05.
they had to redesign it for the 07 and up models cause of the changes they made to the engine, so it made the older one "obsolete" so to speak. just like when the newer version of, say, a video game system is released, the older model will get a deep price cut but the newer will be expensive until the next model is out.
Old Dec 23, 2007 | 02:33 AM
krystof63's Avatar
^ I always thought the only difference they made between the '05 to the '06 & '07 was the exhaust manifold clearance for the SC shaft.
couldn't they just slap on a '05 exhaust manifold on an '07 tC?
Old Dec 23, 2007 | 02:57 AM
gjpjr84's Avatar
the difference is the supercharger itself not necissarily the rest of the engine.
visually, in addition to the adjusted mounting brackets, they have a different locking bolt for the pulley cause of people frauding them out for warrenty work and the shaft bolts up differently to the turbine housing and the intake box is completly replaced instead of just half of it changed out.
Old Dec 24, 2007 | 02:16 PM
since it has a different locking bolt thingie does this stop u from changing pulley? soory newbie here. wat kind of stuff can u do to the old supercharger that u can do to the new one now
Old Dec 24, 2007 | 03:13 PM
gjpjr84's Avatar
you can still unbolt the pulley, you have to go through some drastic measures though, theres a thread somewhere in this section about it. you can do the same things you want with it, its just harder now cause of TRD having to go through even more measures to stop people from frauding them out for work.
Old Dec 24, 2007 | 03:39 PM
if u change the pulley will that make u fail the smog test in CA
Old Dec 24, 2007 | 03:48 PM
gjpjr84's Avatar
no idea...
Old Dec 27, 2007 | 06:35 PM
trdsparks's Avatar
They also changed the fuel/air maps on the 07+ tC's so that is another reason why you can't use the 05-06 S/C on the newer models. It does suck that the 07+ are so much more expensive but as of right now we don't see a drop in the price coming up anytime soon.
Old Dec 27, 2007 | 08:17 PM
GQQSE13's Avatar
Default Re: any idea
i thought it was the same s/c as every years?
Old Dec 27, 2007 | 08:27 PM
trdsparks's Avatar
Nope the 05-06 uses one kit, the 07+ tC's use another kit.
akarnofel
Scion xB 2nd-Gen Wheel & Tire
Aug 26, 2015 07:49 PM
jbernard
Aug 22, 2015 09:14 PM
StxArOne
Scion xA Aero & Exterior
Aug 21, 2015 06:44 PM
Brently1
Aug 12, 2015 10:54 PM
TOOSLOW
Jul 25, 2015 05:19 PM
