How to take off garnish?
Old Dec 22, 2007 | 09:00 PM
CRUZtc8's Avatar
Default How to take off garnish?
Hey guys I'm having trouble taking the garnish off the hatch can anyone help?
Old Dec 22, 2007 | 09:14 PM
BZinn1's Avatar
Do you meen the tC badge.......try dental floss and saw under it till you get it to come free.....then rubbing alcohol to clean off the tape,then wax and then polish and buff.
Old Dec 22, 2007 | 10:17 PM
CRUZtc8's Avatar
no the garnish it looks like this.. http://cgi.ebay.com/ebaymotors/05-06...spagenameZWD1V
Old Dec 22, 2007 | 10:22 PM
RodC's Avatar
What's the problem you are having? You just have to remove 4 nuts and pull it out.
Old Dec 22, 2007 | 10:30 PM
CRUZtc8's Avatar
I have no idea how to take the garnish off.Are the 4 nuts located under the hatch panels? How do i get to them.
Old Dec 22, 2007 | 10:36 PM
RodC's Avatar
Yeah, start by taking off the hatch panel. In order to do that, you also need to remove the 3 plastic trim pieces around the top and sides of the hatch. When you are removing the panel, it just pulls off, but it takes some force. You just have to pull it down until it pops loose. It's held in place by 8 or 10 plastic pegs in different locations. Oh, and there are also a couple of screws which you need to remove, located by the inside handles. After it pops loose, it should swing down and should remain held in place by the fasteners at the corners, but it will still allow you to access the garnish. The TBL has 4 bolts and the garnish has 4 bolts, so make sure you are working with the correct ones. You don't need to remove the TBL. The garnish bolts are too long for a regular socket wrench, so you will need a deep socket or a pair of pliers to loosen the 4 nuts. After they are loose, twist them off and try not to drop them inside the hatch panels. You should then be able to push out the garnish by pushing from behind or pulling from the front. It will still be connected by a wire and it might also be a little bit stuck to the TBL adhesive. Once you have pulled it out, unscrew and disconnect the hatch pressure sensor to get the garnish free, and that's pretty much it.
Old Mar 1, 2008 | 07:36 AM
224's Avatar
224
Can SOMEONE PLEASE SHOW PICTURES OF THIS?!?! I Dynamat'ed my hatch so I need to know exactally where to find the bolts.
Old Mar 1, 2008 | 07:45 AM
FLINTstone's Avatar
thank phil over at oznium for this one.
http://www.oznium.com/articles/17
TTCCC
Sep 15, 2015 02:12 PM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
iKONA
Jul 18, 2011 02:33 PM
iKONA
Scion tC 1G Aero & Exterior
340
Nov 26, 2008 05:11 AM
