airbag light removal
Old Dec 27, 2007 | 08:50 AM
exmurderblah's Avatar
Default airbag light removal
got a fix it tix on xmas eve for not having an airbag in my tc.gonna go back to stock steering wheel but my light will still be on.they will check for it since chp pulled me over.who ever can do gauge color swap in la/oc riverside /ie etc help? or any one here with instructions.i just wanna remove the light bulb that lighst up this specific function so cops wont know its on.they will think it works. no way to test if airbag works.
also got a fix it for tails and no front plate. all on xmas eve.3:40pm.gf in car dressed super nice.i the same.he even asks if we are related after i tell him im on my way to mu gfs parents house for xmas.popped my hood.i have a header but my heatshield trick worked so i got lucky.i was super nice to the cop.i was going 40.speedlimit is 45.he was such a *****.hassled me .
thanks,
louie
Old Dec 27, 2007 | 09:15 AM
BlizZard's Avatar
why did he even pull you over?
Old Dec 27, 2007 | 09:28 AM
to be honests i dont know y he pulled me over.his original answer was because my tailights are too dark.it was 340 in the afternoon on xmas eve.he was such an _______.he even said he has seen worse mods on a car.he admitted to that.
Old Dec 27, 2007 | 01:54 PM
DanielNC06's Avatar
what if they plug in2 the obd port?...dont know if thats how they check but its possible...probably not though...
goodluk
Old Dec 27, 2007 | 06:35 PM
engifineer's Avatar
To get rid of the light, simply take the gauges apart like you are doing an led swap and remove that led.
Old Dec 27, 2007 | 06:46 PM
how hard is removing the cluster? can you compare it to another mod? example: header?? and any one think they will use the obd2 port?
Old Dec 27, 2007 | 06:59 PM
bearsfan1172's Avatar
Removing the cluster is very easy. Compared to a header it is nothing. The more difficult will be removing the LED. You might just want to cover it with something. I know Garage1217(something like that) had a diagram of the gauge cluster and which LED's do what. Im sure someone else can give more specific instructions.
My thing is, I didn't know it was illegal to not have airbags. There are plenty of older cars still floating around that don't have them. It doesn't make sense
Old Dec 27, 2007 | 09:44 PM
engifineer's Avatar
The tech section on here has a gauge led swap tutorial. Tells you step by step how to take it apart.
Getting it out takes me less than 3 min. Taking it apart requires removing the front bezel, removing the needles, taking the gauge faces off and then removing the white bezel and the LCD display. You then have a bare board to work with.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
randomsuper
Feb 4, 2015 10:13 PM
fur_pig
Scion tC 1G ICE & Interior
Jan 27, 2015 12:52 PM
