Installed Engine damper
Old Dec 28, 2007 | 04:30 PM
172's Avatar
172
Default Installed Engine damper
just install weapon R engine damper.
wan to ask if there's a clearer instruction online on how to adjust the tension?
DIY so not sure if its right,havent test it out yet
Old Dec 28, 2007 | 08:51 PM
burstaneurysm's Avatar
As far as I know, the Weapon R isn't adjustable, only the Ingalls Stiffy.
Old Dec 29, 2007 | 03:29 AM
jct's Avatar
jct
weapon R is too adjustable cause i have it
to stiffen it up just tighten it up, to unstiffen it just loosen it up... lefty loosy, righty tighty heh
i have mine set up in between i only hear the vibrations from it when i'm at idle
Old Jan 1, 2008 | 05:41 PM
172's Avatar
172
did i install the right way? or is it the other way round as i seen in another pic?
Old Jan 1, 2008 | 06:14 PM
dexter_5000's Avatar
looks right to me. my ingalls is that way.
Old Jan 1, 2008 | 11:57 PM
jct's Avatar
jct
its installed the correct way
Old Jan 2, 2008 | 05:55 AM
172's Avatar
172
i saw some post here is like this?
his seems to be in inverted postion compared to mine,notice the tension adjusting nut in nearer to the front of the car,whereas mine is near firewall
Old Jan 3, 2008 | 04:32 AM
jct's Avatar
jct
either way works it does the same job anyways...
Old Jan 3, 2008 | 05:06 PM
BurxBox's Avatar
did you notice a difference? throttle respones,smoothness in launch?
Just wondering. I was thinkin of getting one
How much are they running? Ingalls and WeponR
Old Jan 4, 2008 | 03:41 AM
jct's Avatar
jct
it'll make that awful wheel hop go away with the added rattling noise :D
Old Jan 11, 2008 | 11:32 AM
172's Avatar
172
i noticed that the rattling sound get louder each day,normal?
i've check the tension,all tight!...
Monkey343
Scion xD Suspension & Handling
Nov 10, 2016 02:07 PM
A1tc2
Jan 14, 2015 02:43 PM
TheTripleC
Jan 4, 2015 06:46 PM
eric_m
79
Mar 17, 2013 12:21 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
