coilover owners, what have u done to make ur drop lower?
Old Jan 4, 2008 | 03:23 AM
05FMtC's Avatar
Default coilover owners, what have u done to make ur drop lower?
has anyone removed those collers, u know the ones that you spin up or down to adjust the ride height so that your max drop is lower then it is. i got the ss-p and i wish the front went down like just a 1/4 inch more. the ssp has 2 collers i guess to lock them in place but i think when they are dumped all the way down u dont have to lock anything since there are no more threads for the coller to spin down on. im just wondering if this is safe to do. i really do not want to get a new set of coilovers when i can just do this. so please post up. and if someone is going to say somthing like, "its just a 1/4 inch" it is a matter of tucking tire and i want to tuck tires in the front dammit! lol. thanks in advance.
Old Jan 4, 2008 | 04:43 AM
O5_TRD_tC's Avatar
what size rims r u running?
Mines aren't maxed out and i have -1 finger in rear and 0 finger front.
Maxing them out also causing the struts to go out faster.
Old Jan 4, 2008 | 07:13 AM
05FMtC's Avatar
18x8 225/40/18 i want to tuck the fronts BADLY!
how much lower can u go in the front? what tire size are u running?
Old Jan 4, 2008 | 07:27 AM
O5_TRD_tC's Avatar
i dont really want to go any lower haha
Old Jan 4, 2008 | 09:07 AM
tC9o9's Avatar
i am running 245/40/17 and i am maxxed out up front, i have about 1/2 finger gap on my ss+p's
i know what you are talking about.. and by removing that locking collar, what happens if you ever want to raise the car up one day? how will you do it?
also, 05_trd_tc, how does maxxing them out make the shocks go out faster?? from the looks of it, the lower i go, the more the spring is decompressed??
i dunno... the main reason i got the ss+p's was because they are rebuildable
Old Jan 4, 2008 | 09:31 AM
O5_TRD_tC's Avatar
from what i read on other boards it causes the shock to go out faster im not 100% sure.
But the lower u go also more bad things happen i.e. scraping , more neg. chamber, rubbing, etc...
Plus the lower u go doesn't = better handling.
Old Jan 4, 2008 | 03:26 PM
DonNguyen's Avatar
the shock will go out faster cuz it will give it farther travel and the more it travels, the faster it will go out...
Old Jan 4, 2008 | 03:34 PM
05FMtC's Avatar
well mine are already as low as they go in the front and its been like that for a while now. im not as worried abt the shocks going out. i also have new end links for the front sway bar. anyone kno if thatll help?
Old Jan 4, 2008 | 03:39 PM
O5_TRD_tC's Avatar
so u want the slammmed look...
Old Jan 4, 2008 | 07:09 PM
05FMtC's Avatar
yeah i want that ____ low.
Old Jan 4, 2008 | 07:34 PM
tC9o9's Avatar
he doesnt want the look, he wants to be slammed
Old Jan 6, 2008 | 01:57 AM
Karbon_tc's Avatar
the problem u'll run into is being able to turn the front tires... its way alot of trucks wit air bags ride with the front higher. if the front is too low, when u turn the turn turns sideways, right into the fender or wheel well. usually why the fronts are always a tad higher.... i had stech springs b4 and it was okay, i bought some cheap springs off ebay and cut some coils off, its -1 finger all around but when im on the highway taken and exit ramp going 30 or so... i start to turn it rubbs the inner plastic and sometimes more if the wheels are turned all the way. just something to think about too. i also have the rs1 lip kit and its literally 3in off the ground...looks cool but it scraps all the time, another thing is my exhaust sometime clings on bumps.
btw im on 255/35/18's
Old Jan 6, 2008 | 06:25 AM
05FMtC's Avatar
ill probably keep the same tire size i have now, 225/40/18. i see what ur sayin with the rubbin but it aint a thing for me b/c i dont have fenderliners in the front anyways. lol. and the offset of my wheel/spacer combo will be perfect so that i wont rub. and even if i do, the ss-p have camber plates built in, ill just add some negative camber so the wheels will clear the fender better and not rub. im going to just remove the coller on the bottom and see how it goes. i think i got some end links also for the front sway bar. some ppl have told me that thatll solve the problem b/c the sway bar susposedly hits the A arm when u slam the car. however i couldnt seem to find where the 2 were making any contact nor do i hear ne metal to metal noises while im driving.
Old Jan 6, 2008 | 09:35 PM
Karbon_tc's Avatar
good luck, post some pics up when ur done
Old Jan 12, 2008 | 10:40 AM
TCfanatikk's Avatar
i love my ksport but getting rid of it soon
Old Jan 12, 2008 | 02:23 PM
davedavetC's Avatar
i love my H&Rs i can tuck the front and the rear :D
Old Jan 15, 2008 | 12:53 AM
greddy05tc's Avatar
when i had mine dumped all the way down with a set of 225/45/18's thefront and rear were both tucking tread.
Old Jan 15, 2008 | 12:57 AM
05FMtC's Avatar
Originally Posted by greddy05tc
when i had mine dumped all the way down with a set of 224/45/18's thefront and rear were both tucking tread.
yes i believe that b/c 225/45 = taller then a 225/40. so ya a 45 will tuck. right now the fender is right at the tire so with a 45 i can tuck but im lookin to keep the 40 profile. however, u got ne pics of ur car with 45's ?
Old Jan 15, 2008 | 02:24 AM
greddy05tc's Avatar
Old Jan 15, 2008 | 02:29 AM
davedavetC's Avatar
thats sick
