TC Air Ride Suspension
Old Jan 6, 2008 | 07:46 PM
TC-hotb's Avatar
Default TC Air Ride Suspension
I have a new air ride installed into my TC and everything was working good, and now the compressor won't turn on and neither will my speakers.... The compressor is attached to my amp for my speakers...the installers did it. (Is that right?) Well anyways, the system won't turn on, so I can't move. I checked all the wires, air hoses, battery, amp fuse, etc.... and everything is good, attached correctly, no leaks. etc. If any one has an idea of what might be the problem, please shed some light. Thanks.
Old Jan 6, 2008 | 07:51 PM
macncheese's Avatar
Did you check the fuse for the amp wiring? There should be a fuse close to the battery on the wire that supplies the amp with power.
Thats pretty cheap of the installer to not run a dedicated power line for your compressor, which probably draws a lot of power but I guess if you have a large enough power cable it should be ok.
Old Jan 6, 2008 | 07:54 PM
bBlover's Avatar
its not ACC AirRunner is it?
Old Jan 6, 2008 | 08:13 PM
TC-hotb's Avatar
To tell you the truth, I got it as a Xmas gift and all I know right now is that it's a 'Plug n Play'. I am trying to get the manufac from the person who installed it.
Old Jan 6, 2008 | 08:39 PM
TC-hotb's Avatar
I started to play with the wires, and it works when its hooked up to the 12-V wire from my amp but not the input....where it would normally turn off when I turned off the car. So hooked up to the 12-V wire it fills up the tank and allows me to lift, but it doesn't turn off when the car is off. Does this make any more sense?
I wish I could be more help, but I'm not really that car savvy. I love cars, and my Scion espically, but the farthest I have gone on repairs is a break change, tire rotation, and an oil change.
Thanks for everyones help.
Old Jan 7, 2008 | 02:19 PM
06scioxb's Avatar
Team XcelsiA
Team Sushi
you have it direct to 12v which is the batery you need to hook it up to thr remote wire from the amp so when you kill the car it also turns off hope this helps
also keep in mind it might just be to much juice that is pulling when it is trying to fill the tank which will cause fuses to pop or wires to heat up just find a better source of 12 v
Old Jan 7, 2008 | 02:26 PM
Dam262a's Avatar
i know a plug n play system...on some website....i cant remember right now...but what i heard about that website is there stuff is poorly made, lets hope that its not the same thing.
Where did you get it installed?
Old Jan 10, 2008 | 02:55 AM
TC-hotb's Avatar
Ihave it wired the the 12v now, thanks for your help ;o)
I had it installed by a dealership called 'Lawleys' down in AZ. I hope it's not the same system that you heard of, that's all I need is bad luck.
Old Jan 10, 2008 | 04:26 AM
Dam262a's Avatar
Airbagit.com is what i was talking about..
Old Jan 10, 2008 | 06:26 AM
kevsXB's Avatar
how is everything going?
Old Jan 10, 2008 | 03:24 PM
TC-hotb's Avatar
No it's not from airbagit.com. It was bought from a direct warehouse in PHX.
It's going good, thanks. It's all a learning experience. frustrating, but fun.
Old Jan 10, 2008 | 06:30 PM
Dam262a's Avatar
can u tell me what it is....plz do you know?
Old Jan 10, 2008 | 06:33 PM
lil_will's Avatar
ScionERA
Is that the "Lawleys" in Sierra Vista, AZ?
Rampage8804
Mar 14, 2015 03:17 PM
peterskin64
Mar 13, 2015 03:24 AM
boxzila
34
Jan 12, 2004 03:27 AM
ScionVan
11
Dec 2, 2003 09:37 PM
ScionOnDubs
Nov 10, 2003 10:03 PM
