$100 for induction service? Worth it?
Old Jan 8, 2008 | 12:33 PM
tjbartjr's Avatar
Default $100 for induction service? Worth it?
So the dealer wanted to charge $100 for an induction service.. is that worth it, or should I just pour the can of whatever they use in there myself? There are no emissions laws in Hall County, no one will care if there's a big black cloud billowing out behind me... :D Anyone else get this, think it's a good deal or a rip off? Car's at 46K hard driven miles, btw.
Old Jan 8, 2008 | 02:04 PM
blazeplacid's Avatar
is it like an injector cleaning?
If so just go buy some seafoam and pour it in the gas tank.
That or put like 2 table spoons thourgh the PVC valve after it has been driven awhile. Pour 2 tbl spoons in at around 2k rpm. You will get heavy smoke out of the exhaust so be sure your in an open area
Old Jan 8, 2008 | 04:17 PM
bigwillystyle23's Avatar
mm i love seafoam. i dump a can in the gas tank every once in a while but after your car gets a few miles on it just run a third of the can thru the pcv valve and put a third of it in your oil and the rest in your gas. it works real good. it is only about 6-7 dollars a can and if your place is charging your 100 bucks for something like that they must be smoking more crack than whitney houston.
Old Jan 8, 2008 | 09:17 PM
dos_techie's Avatar
Most dealers charge that amount. The dealer where I work at charges $129 for the service. It includes a can of throttle-body cleaner(sprayed on TB plate),a bottle of fuel injecteor cleaner(poured into tank), and a bottle of vaccu flush (poured through a vacuum hose). All can be purchased at your local auto parts. After all, you are paying for the product and the service.
Old Mar 25, 2008 | 06:25 AM
cmv138's Avatar
im asking tis b/c i dont want to mess anything up...
where is the PCV valve located at? im planning to get some seafoam and want to do this the correct way. i have a s/c on the car now. can i just use the small vac line thats on top of the bpv?
Old Mar 25, 2008 | 07:41 AM
protocold's Avatar
$100 may or may not be a good deall, all depend on the services.
Old Mar 25, 2008 | 01:41 PM
nauticac's Avatar
you can pour seafoam right through the throttle body directly as well.
Old Mar 26, 2008 | 03:12 AM
where is the pvc located?
i looked but found nothing
but this was at a fast glance
anyone point me in the right way
Old Mar 26, 2008 | 03:47 AM
cmv138's Avatar
another thing is that i have 32K miles on the car. is it even going to help with only 32k miles?
Old Mar 26, 2008 | 06:55 PM
probably. disconnect the vacuum line from the brake booster thing and let seafoam suck up that hose. just do a tiiiiny bit at a time though. have a friend hold the idle about about 1200 rpm while you do it. then shut the car off for a few minutes and fire it back up then give it hell.
Old Mar 26, 2008 | 06:56 PM
http://youtube.com/watch?v=SZf4WXwVL_E
I FOUND IT
heres the vid! ^^^
Scionxa180
Aug 30, 2015 04:12 PM
StxArOne
Scion xA Aero & Exterior
Aug 21, 2015 06:44 PM
kanundrum
Regional - Mid South
Aug 4, 2015 04:23 AM
TOOSLOW
Jul 25, 2015 05:19 PM
ScionPhreak
Jul 16, 2015 10:13 PM
