Rear Speakers not producing full-range
Old Jan 13, 2008 | 01:49 AM
Travis71902's Avatar
Default Rear Speakers not producing full-range
I put some 3-way coaxials in the back for fill and ran them off the factory wiring, but I'm not getting full-range from them?
Any advice.
Old Jan 13, 2008 | 04:02 AM
combatsteve's Avatar
check your crossovers on the deck if you have any. Also did the speakers come with their own crossovers? If so did you hook them up correctly?
It has to be one of those two things if you are running them straight off the deck with the factory wiring.
Old Jan 13, 2008 | 04:52 AM
deathbyc4's Avatar
could be the wattage of the speakers being too high if you have a oem deck. if not, then crossover or maybe wired backwards, dunno without looking at it.
Old Jan 13, 2008 | 01:48 PM
rocketgyrl's Avatar
This is a myth.
Old Jan 13, 2008 | 03:03 PM
blazeplacid's Avatar
well to a point.
Some aftermarket speakers are inefficent enough to sound like crap,
but the stock deck should still be ok
Old Jan 13, 2008 | 11:44 PM
Killface's Avatar
Try changing the "vehicle type" setting. The tC setting puts very little power through the rear speakers.
Old Jan 13, 2008 | 11:45 PM
rocketgyrl's Avatar
No. The power ratings of speakers is a general indication of the amount of thermal capacity the motor structure can handle.
In your example, it is the AMPLIFIER at fault for clipping due to the inability to meet the current demands of low frequency reproduction.
The OP makes no mention if by "not getting full range" it is the bass or the treble that is missing. I suspect there may be some jumper wires either missing, or not connected properly on the speaker's terminals. There is the possibility that the tweeters are blown. Are the speakers new and/or tested to work 100%? Which make and model are the speakers?
Old Jan 14, 2008 | 02:00 AM
They're just some 3-way, 180 watt Pioneer coaxials. I hooked them directly up to the +/- from the oem harness. The speakers are producing only highs. I tested the speakers and they are in fine condition, plus I've heard them play the full range that they should be in a different car. I still got the factory Scion HU and thats what I suspect is the problem. I didn't think to change it from "FEEL", which its on right now. But I don't know....
Old Jan 14, 2008 | 02:02 AM
Oh, and thanks for the posts thus far guys. Its much appreciated.
Old Jan 14, 2008 | 02:46 AM
hold down the ssp button for like 3-5 seconds and you will have the option to change from tc/xb/xa
i think xa is what i liked best
Old Jan 14, 2008 | 10:04 PM
I think your speakers might be bad then. There are no x-over's on the factory deck so it can't be that and those speakers don't have external x-overs that you could have hooked up wrong. My best guess is that the voice coil is seized up or fried on the mid and therefore you are only getting the highs.
If you have a digital meter test the speaker for resistance. I am guessing it doesn't read 4 ohms.
MRE
Feb 16, 2016 11:26 PM
linlow
Scion tC 1G ICE & Interior
Dec 14, 2014 12:56 AM
TOY_bB
Dec 15, 2003 07:41 AM
shaefner
12
Oct 8, 2003 01:46 AM
vpkb
Sep 30, 2003 07:48 AM
